King Tut's PTUNING Turbo Kit Build
#81
is the GTX3076 worth it over the GT3076 for 93 pump and street use only? from what i have researched the gtx shines in higher boost applications ie. E85 or c16
i plan to be 100% pump gas on a 2007 s2k... also, do you recommend any parts that come on the kit to be beefed up or maybe swapped out for something else? i know you know this kit inside and out... and did you ever send out the ECU to Hondata, or did you just use a manual boost controller?
#82
Which solenoid? I have the hondata 4port and cant get it to work properly. Basically can get 11 or 13psi, then jumps to over 20psi, cant target anything in between. Please let me know if you can get yours to work. I really like the response of the 4port over the 3 port and dont want to switch (per my tuner) if i can figure this out some way.
#83
#84
Yours is a 3 port Mac solenoid Tut.
#85
Is this AC re-located or taken out? I ask because it also looks like u used a heater valve re locater, I keep looking at my heater valve and re locater and it looks like the hard lines are just in the way of the valve going where it needs to go towards the battery.
#86
#88
#90
Nice build. I track my s2000 on the streets . No entrance fee....gtx3076 pfab elt 11.5 psi on 91 octane... id 1000s fbm340lph
Rohana10
Member S2000 Classifieds and For Sale
12-20-2017 01:18 AM
