75k service ?
Old 08-29-2007, 12:56 PM
S2Kyle01's Avatar
Default 75k service ?
can someone point me to the link that shows you what gets done for 75k service... there was a thread i found a few months back that had all the service's and tells you what gets done at each set of miles and now i cant find it anywhere!?
Thank you
Old 08-29-2007, 05:38 PM
R3DS2K's Avatar
75000 MI or 120000 KM
Inspect
Brake Hose/Line Notes
Brakes and Traction Control Notes
Inspect front and rear brakes.
Cooling System Notes
Check all hoses for damage, leaks or deterioration. Check fan operation.
Exhaust System Notes
Fluids Notes
Perform at mileage interval or every 12 months whichever occurs first. Check the level and condition of all fluids.
Fuel Supply Line Notes
Parking Brake System Notes
Steering and Suspension Notes
Tie-rod ends, steering gear box, and boots. Suspension components. Driveshaft boots.
Tires Notes
Check tire inflation and condition.
Replace
Engine Oil (E) Notes
Oil Filter, Engine (E) Notes
(S) = Service Warranty Requirement
(E) = Emission Warranty Requirement
(B) = Both Service and Emission Warranty Requirement
this is for normal condition
Old 08-29-2007, 05:39 PM
R3DS2K's Avatar
THIS IS FOR Severe Service
Inspect
Inspect cooling system hoses and connections.
Fluids Notes
Lighting and Horns Notes
Inspect all lighting functions.
Tires Notes
Vehicle Notes
Inspect underbody every 12 months or 15,000 miles.
Lubricate
Hinge, Door Notes
Locks Notes
Replace
Air Filter Element (B) Notes
Cabin Air Filter (S) Notes
Engine Oil (B) Notes
Perform at interval or every 1 year, whichever comes first.
Fluid - Differential Notes
Old 08-29-2007, 05:40 PM
R3DS2K's Avatar
just ignore the word NOTES
i copy this from alldatapro
Old 08-30-2007, 03:40 AM
S2Kyle01's Avatar
thank you guys...
Old 08-30-2007, 03:48 AM
S2Kyle01's Avatar
Anyone have a link on replacing Timing chain tensioner ?
Old 08-30-2007, 04:46 PM
METATRON's Avatar
It will tell you in your owner's manual
Old 08-30-2007, 07:18 PM
R3DS2K's Avatar
https://www.s2ki.com/forums/index.ph...c=320897&st=25
go down a little
enjoy
Old 09-02-2007, 09:21 AM
S2Kyle01's Avatar
what about changing the oil pump and water pump... when should that been done ?
jlammy
07-01-2009 11:37 AM
hylysly
04-08-2008 06:03 PM
dolebludger
03-09-2007 02:23 PM
hapa
07-06-2006 12:44 PM
reds2
04-14-2005 04:10 PM
Quick Reply: 75k service ?
