EVS Tuning Hgh Flow Catalytic Converter
Old 09-12-2016, 10:35 AM
Former Sponsor
EvasiveMotorsports's Avatar
Default EVS Tuning Hgh Flow Catalytic Converter
Hey guys,
Just wanted to share with you guys our new High Flow cat.
EVS Tuning High Flow Catalytic Converter (HFC) is a direct bolt-on replacement to the restrictive factory catalytic converter.
- 70mm or 63.5mm Stainless Steel tubing and flanges
- Full TIG welds
- Direct OEM Fitment with bolt on installation
- All Hardware and gaskets Included
- Built in CEL fix
-200 cel cat. Free flowing
Pricing info can be found here
https://www.s2ki.com/s2000/topic/116...tic-converter/
Old 09-12-2016, 10:47 PM
MorngWoodStewie's Avatar
Looks stellar!
Old 09-13-2016, 12:23 AM
andrewhake's Avatar
Looks very nice. House is sound compared to using a test pipe? Also does the 70mm version start at 60mm on the header side and then step up to 70mm after the cat?
Old 09-13-2016, 06:07 AM
TsukubaCody's Avatar
Taken from the other thread on this:
Originally Posted by EvasiveMotorsports
Originally Posted by //steve\\' timestamp='1473214122' post='24056328
Which size is pictured above? If the 70mm it almost has the illusion that it's 60mm into the cat and 70mm out of it? Are the 70mm versions 70mm from the header back?
mix of both pictures. 70mm is 70mm all the way through
I'll be picking up a 63.5mm piece over the winter, should sound sweet with my 60RS
Old 09-15-2016, 04:16 AM
MrCouch's Avatar
just grabbed one of these in 63.5 ill do a little write up with pics once i get the miltek exhaust im waiting for as well.
Old 09-15-2016, 09:32 AM
sleep's Avatar
could you post a before/after video on your stock exhaust too mr couch?
Old 09-16-2016, 03:29 AM
MrCouch's Avatar
Yea i don't see why not.
Old 09-17-2016, 10:00 PM
davidc1's Avatar
I'm assuming this doesn't have CARB approval?
Old 09-18-2016, 02:00 PM
GOGPWS2K's Avatar
It takes a lot of money to get an item CARB approved
Old 09-19-2016, 08:37 PM
AngryTurtle's Avatar
And I dont think you can get a high flow cat carb approved.
Quick Reply: EVS Tuning Hgh Flow Catalytic Converter
