Front sway bar end links for S2000
Old 03-26-2017, 11:10 AM
DaveMunsey's Avatar
Default Front sway bar end links for S2000
I autocrossed my new to me S2000 yesterday and today I discovered that my left front adjustable sway bar end link was broken in half. I installed a bigger front sway bar and I had a hard time finding any adjustable end links for it. I ended up buying a set of brand X end links off E-bay. Is there a source for high quality end links for the front? I am also wondering if I have contact between the front Eibach sway bar and the bracket on the koni yellow shocks that hold the brake line. When I jacked up the other side the end link was not broken but there was contact between that bracket and the sway bar. When it is on the ground I can slide a finger width between the 2 parts. Trying to figure out if the end link broke because it is junk or if it broke because it made contact with the shock bracket when it should not have? Any thoughts or advice greatly appreciated.
Old 03-26-2017, 12:18 PM
jst2878's Avatar
Gendron has endlinks available for sale. Not sure where he gets them from
Old 03-26-2017, 12:30 PM
sillyboybmxer's Avatar
Hit up anorexicpoodle on here. He sells adjustable endlinks. You can also view his store and buy on ebay.
Old 03-26-2017, 12:50 PM
C4vettrn's Avatar
I know Mooge makes some replacements however they are not adjustable. If the bar/end link wasn't making contact with coil over when installed it may be off center from the other side breaking end link (just a guess) do the Eibach bars have inside collars ?
Old 03-26-2017, 02:10 PM
SmokeyGatto's Avatar
i got mine off poodle, they have zero corrosion and i'd buy another set but they're still like new
Old 03-26-2017, 05:12 PM
DaveMunsey's Avatar
Thank you for the info.
Old 03-26-2017, 05:13 PM
DaveMunsey's Avatar
Thanks for the info.
Old 03-26-2017, 05:21 PM
DaveMunsey's Avatar
That is who I bought my end links from. So if you know these to be good strong end links, not pot metal, then it must mean that the end link broke from the sway bar making contact with the shock body bracket. I had someone install these for me and that was my first mistake.
Old 03-27-2017, 12:31 AM
DaveMunsey's Avatar
If anyone is interested in good brand name adjustable end links I found some made by Whiteline at Suspension.com. For the front it is the KLC140-060. They adjust in length from 60 to 80 mm.
Old 03-27-2017, 01:58 AM
Sponsor
SakeBomb Garage's Avatar
Dave, we've got some absolutely bullet proof sway bar links coming out shortly if you haven't already ordered. We make them from the motorsports line of rod ends from Aurora Bearings with our own center mounts... if you can break one we'll give you a metal. They're lifers. Shoot us a PM if we're not too late. Good luck!
Quick Reply: Front sway bar end links for S2000
