S2000 Stock class autocross information
#141
Couple of questions. I ran BS last season, and will be there this season as well.
"Number two: Seat position! (move it up!)"
What do you mean by this? How tall are you? I am 6'3" and have to have the seat back all the way.
"RE71s(225s on all 4, best tire I've found so far)"
I also ran RE71rs and I loved them. What size were you running? I could only get them (and i think there is only the one size for us) in 225/50r16.
"Karcepts front bar(on third setting)"
Have you ran the Small Fortune bar? I might be buying one from a local guy, just curious on the differences.
Thanks for all the info!
Im running the 225 50 16s as its the biggest they offer in our size. Man how I wish we could run the ap2 wheels.
As the other guys have stated the SFB should be just as good but I have no experience with one to tell you what setting work in BS.
What region do you race at?
bergi85 (02-16-2017)
#142
Im 5 10 but even at 6 3 I would think the correct seating position would still need to move up just a bit. At the very least make sure the rear of the seat is not leaned back. It feels weird at first but you want to be on the steering wheel. Sunday I forgot to move mine up my first run. Picked up like 7 tenths the next run when I did.
But the pièce de résistance of the Karcepts bar is the arc on the arm that allows stiffness adjustments without adjusting the length of the links or disconnecting both links. the link fits a groove in the arm of the bar that lets it be tightened or loosened with one wrench. It is simply a work of art and engineering.
However, if you have the SF bar at a discount it is probably worth a try. Otherwise, I'd go Karcepts. These are pics of the Karcepts and Small Fortune bars.
#143
Thanks for the help!
#144
Thanks! Yeah I am working on figuring out the price with him now. Either way I am excited to run with one of them this season!
#145
Echoing what everyone else is saying the "correct seating position should have your arms bent 90 degrees at your elbows. Heres a good video to watch on the subject.
The Biggest Driving Mistakes - Correct Your Driving Mistakes
I have the Gendron bar. I haven't tried to Karcepts bar but can't imagine it would be any worse performance wise. I would go with whatever is cheaper.
Good luck this season!
bergi85 (03-01-2017)
#147
#148
So I literally just signed up for a SCCA membership because I want to finally, after years of owning my car, get into autocross. I need some help figuring out what class I should be in because reading the Solo rule book is eye-glazing.
My car and mods:
2004 S2000
OEM hardtop
Fr. 225/45/17 and Rr. 255/40/17 on stock AP2 V1 wheels
KW Variant 3 coilovers
S2000 CR front sway bar
Hytech Header with test pipe
T1R 70R-EM Sparrow exhaust
Science of Speed stainless steel brake lines
And that's it. Not a lot of modifications but I just can't tell where my car would fit in. I will be adding Bride Vios III Japan seats with Bride rails soon, if that changes things. Any help is appreciated and thanks in advance.
My car and mods:
2004 S2000
OEM hardtop
#149
My car and mods:
2004 S2000
OEM hardtop
2004 S2000
OEM hardtop
I'd get a highflow cat instead of the test pipe, some 17x9" wheels and go have a blast in STR.
#150
Has there been an indication on the best tire and tire sizes for 2017? Is the Rival S better than the RE71r? Is the Direzza III the new leader? It looks like the RS4 isn't.
And to sizes. Still at 245/40-17 front? Is 245 square preferred over 245/255? I will miss the 225 front; it stopped my car from scrapping exiting our driveway.
