S2000 Street Encounters Stories of on-the-road exploits and encounters.
stock/near stock 1/4 mile times
Old 11-17-2014, 06:27 AM
  #211
9000_revs's Avatar
Originally Posted by Da New Yawka
Originally Posted by hondarid3r' timestamp='1394971747' post='23065032
My best pass. Stupid fast for a bolt on s2000. Just intake, header, exhaust.
Sent from my iPhone using Tapatalk
What brands??
Js racing header, 70mm Invidia test pipe. invidia n1 dual, and k&n fipk intake.
Old 01-18-2015, 09:00 AM
  #212
siik_ap2's Avatar
Originally Posted by 9000_revs
Originally Posted by Da New Yawka' timestamp='1405037035' post='23238664
[quote name='hondarid3r' timestamp='1394971747' post='23065032']
What brands??
[/quote]
That's pretty good for straight bolt ons. The 60 foot is key
Old 09-21-2016, 08:00 PM
  #213
siik_ap2's Avatar
Went to the track tonight. Best 60' was a 1.9.
Last pass before snapping an axle car went 12.953 @ 107.53. 60' was only a 2.007. Pretty confident the car can go 12.6-12.7 with more seat time. Mods are still the same expect car is now on e infinity. Weight is the same but will be looking to shed another 100-150 pounds and car should be a solid 12.5 car all day.
Pics and videos will be on my ig @ honda_fiend
Old 09-22-2016, 03:10 PM
  #214
K20iVTEC's Avatar
Wow 400lbs of weight reduction is ridiculous nevermind another 150lbs. I have similar mods and only trap 101... Very nice runs! I forgot what the stock ap2 4th gear top speed is, are you shifting into 5th?
Old 09-22-2016, 04:18 PM
  #215
K20iVTEC's Avatar
I also went to the track last night. Only 2nd time at the track with the s2000. My best time was...
60'... 2.09
1/8... 8.83 @ 81.06
1/4... 13.65 @ 101.67
Mods: Custom 3.5" intake, oem TB bored to 70mm, port matched IM, PLM header, test pipe, hks single, ap1 intake cam, kpro, 4.57 gears... Made 240whp on jeff evans dyno
I think the gears are actually hurting my 1/4 as i have to shift into 5th at ~92mph. Figured i should be trapping higher also with my mods and power. All 3 runs last night were 101mph. Is this good? I'm not really happy with the 13.6. Figured if i can get a 1.9 60' then i should be good for a 13.4...
Old 09-22-2016, 06:00 PM
  #216
siik_ap2's Avatar
I keep it in 4th I cross the traps at about 8850. I got spare doors I'm going to cut and remove the rest of the a/c crap probably radio, carpet, and sound deadening.
Old 09-22-2016, 06:04 PM
  #217
siik_ap2's Avatar
60'... 2.09
1/8... 8.83 @ 81.06
Shifting into 5th is hurting you for sure. That's why I opted to keep Stock gear ratio and just raise the limiter, although the shorter gears will help get the car moving easier. We have similar mods minus cam, gears, and weight. Some drag radials will deff help you.
Did you do before and after of the cam? I have a set of ap1 cams I want to test maybe in 2-3 weeks
I went 13.4 street tires at 105 with a 2.1 60' so your basically there just less mph.
Old 09-24-2016, 10:59 AM
  #218
K20iVTEC's Avatar
60'... 2.09
1/8... 8.83 @ 81.06
No i never got a before dyno with stock ap2 cams. Picked up a set of ap1 cams for cheap so i threw it in while i had the valve cover off during the k-pro install. My tuner couldn't say whether the cam helped or not but he did say my car was the strongest ap2 with my mods that he's ever had on his dyno. Would like to see your results with just the cam swap...
Old 10-12-2016, 04:54 PM
  #219
siik_ap2's Avatar
Originally Posted by siik_ap2' timestamp='1474596278' post='24068093
[quote name='K20iVTEC' timestamp='1474589930' post='24068030']
60'... 2.09
1/8... 8.83 @ 81.06
[/quote]
I will be tuning before and after ap1 intake cam next Friday so hopefully I get some positive results finally know if the cam really works.
Old 10-13-2016, 04:21 AM
  #220
K20iVTEC's Avatar
Nice! Can't wait to see the results...
Quick Reply: stock/near stock 1/4 mile times
