Pulsing shake or vibration from 73 - 88 mph
#22
alignment issue? i remember when i had my old car (95 honda accord) it would start vibrating at higher speeds on the freeway. Once i got it aligned it all went away.
#23
You could try to take it to a place that does on car balancing. Just remember that they have to spin both rear tires at the same time because of the differential. They should at least be able to diagnose where the vibration is if it can't be balanced by wheel weights.
#24
Take each wheel off get a torque wrench and reset each of them. Sometimes dudes just use an air wrench to get them on. Use the star pattern, finger tight then a half turn each until you have to use the torque wrench. Mind the star pattern throughout. If that doesn't help and non of vipers ideas help, then it might just be a bad tire. it happens. I had a set of tires put on my GF civic and it vibrated badly. It was a brand new tire that was bad, it happens.
#25
Mine is also a 2002 and has this issue from 73 to 79mph. Not as bad though as some others I have driven. I have only noticed this on AP1's. I also have tried different rims and tires with no difference. I am starting to wonder if it is in the driveshaft or trans/clutch. Engine speed make no difference. You can be in nuetral and then vib is still there. I have driven Ubetit's car and we have the same vib. It pulses through the body. We all can't have bad wheel bearings, but it seams like it is the AP!'s with this issue.
#26
I use to have this problem as well from 80+. What I notice on my car was that the little airsplitter, airguard or whatever you want to call it that is located in front of the front tire wasn't there! So the next day I went to Honda and ordered it and the shaking was gone!
#27
Maybe I missed it, but I didn't see anyone ask about HOW the wheels were balanced. And this comment...
...is a little disturbing.
I had a similar problem on a different car recently, and it didn't go away until I had the wheels balanced on a roadforce machine. That fixed the problem like magic. Shops with these machines can be hard to find -- one place to start looking is on the TireRack installation page, but ultimately you may have to make phone calls and ask. HPH
Originally Posted by therealciviczc
The tech did mention that a couple of them were off by a little, but nothing major at all.
#29
Originally Posted by david1,Aug 29 2006, 12:36 PM
Mine and Ubetit's wheels have been balanced with Roadforce and no difference.
Tonight or tomorrow I plan to retorque the lugs, check torque on the axel nuts, and check torque on the rear subframe bolts (the cause mentioned by someone in an old thread).
I hate to even ask this, but is there any safe way to run a car with the rear off the ground to see if there is visable wobble? I do occasionally have access to a very nice service facility. Is it really safe to put a car on the rack and run it up to 70mph though?
#30
Its worth noting that he mentioned that two of them had been off. He got them correct. Just to clarify.
