O2 sensors
Old 12-29-2011, 09:43 PM
josh7owens's Avatar
Default O2 sensors
I keep throwing this "secondary o2 sensor high voltage code", who makes the OEM o2 sensors and what should I buy as a replacement. I'm not sure I want to may $230 each for 2 sensors.
Thanks
Old 12-30-2011, 05:55 PM
CoolGuy094's Avatar
Well the secondary sensor is the one that comes after the cat right? So you are having issues with the one after the cat. Is this the same code that test thrown when you run a test pipe? Dont you have a high flow cat? Have you checked the connector to make sure its not gunked up? Its kinda a PITA to get to.
Old 12-30-2011, 08:51 PM
josh7owens's Avatar
No it's the high voltage code which is what you get when the sensor goes bad. From what I've been told
Old 12-30-2011, 11:56 PM
mmm...vtec's Avatar
Have u compared the voltages of both sensors?
Old 12-31-2011, 04:52 AM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
I've always been leary of replacing the factory FRONT 02 sensor with anything other than oem.
But for the REAR (secondary) all it does is monitor CAT activity. So I'd be confident buying a cheap sensor and soldering it in. I'm sure you can just call any auto parts store with your year car and they can give you alternative options to OEM.
BOARDPARADISE
09-07-2017 10:40 AM
xrapidx
10-10-2009 04:11 AM
User 121020
09-11-2009 09:16 PM
nicku
10-02-2006 05:54 PM
Ooalloems2koO
04-19-2005 03:38 PM
Quick Reply: O2 sensors
