Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors
Old 07-05-2012, 05:39 AM
Sponsor
Urge's Avatar
Default Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors
Please email for direct questions & specials or post below to share thoughts & questions with S2KI community!!
Ohlins DFV $2000 List (Email for Pricing)
Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors-s2000-dfv.jpg
  • http://urgedesigns.com/?page_id=340"]Full Ohlins DFV Details & 30+ Reviews[/url]
  • 3rd "Super High Speed" path in addition to the traditional high speed and low speed oil paths
  • Other dampers have a "blow off" valve for "Super High Speed" compression, DFVs have a Dual Flow Valve for Super High speed rebounds
  • Extremely important on the track over bumps at high speed settle the car down more quickly than other dampers, more grip, get power down quicker
  • DFVs have a temperature sensitive needle valve on low speed compression & rebound providing more consistency between cold track and hot track conditions
  • $2000 damper that performs like a $4000 damper
We feel the Ohlins DFVs are severely underrated or unnoticed because they are labeled "Road" & Track. Well they are the best of both worlds and perform better on the track than they do on the road. Yes, they are only single adjustment, but they actually adjust compression and rebound simultaneously ensuring they match. We offer Metric Swift Spring Upgrades if you need more than the Ohlins Spec 10/8 (F/R) Kg/mm.
NEW S2000 Ohlins DFV "R" Option +$900
  • Same DFVs above Custom Valved to URGE Spec
  • Includes new 16/13 (F/R) KG/mm Lightweight & High Travel Swift Springs
  • Free Option to any other Spring/Valve Specs
  • Made to order ~2 week turnaround time
PSi Raceline Ohlins TTX36, 2-Way for $5550 incl Top Hats & Swift Main Springs
$250 for Optional Swift Helper Springs & Couplers
Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors-urge_designs_s2000_ohlins_ttx_01.jpg
  • http://urgedesigns.com/?page_id=342"]PSi Ohlins TTX36 Details[/url]
  • TTX design provides consistent and matching damping for both compression and rebound
  • TTX design reduces hysteresis for ultimate short stroke, high force damping
  • TTX design completely separates compression & rebound settings
  • ~20 lbs. lighter than OEM suspension!! 5 lbs per Corner!!
  • Choose your Spring rate, We recommend 12/10 to 16/13 KG/mm (Fastest FR Time Attack car in the world uses 12/10 KG/mm)
  • Upgradeable to 3 or 4 way adjustability
  • The best Track Damper System available for the S2000
https://www.ohlins.com/about/hall-of-fame/"]National & World Champions using TTX technology[/url]
Essex Track Brake Kit w/ AP Racing Track Calipers & Rotors $2350
Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors-s2000-urge-spec-essex-ap-racing-04.jpg
  • http://urgedesigns.com/?page_id=166"]Full Essex Track Kit details[/url]
  • Saves ~ 15lbs of Rotational and unsprung weight
  • AP Racing CP8350 Calipers w/ S2000 specific bore sizes for ABS matching
  • True Track Calipers used in Late Model Racing & European Rally Car
  • 299mm rotors much less rotational weight than other track kits, same rotors used on 500HP, 2800 lbs short track stock cars
  • 32mm thick rotors with much wider vanes improve air flow ~20 to 50%
  • Full floating rotors significantly reduce cracking w/ Spring Clips to reduce rattle
  • Reduce Tracking costs, ONLY $165 replacement rotor (vs $200 to 300 for other 2 piece)
  • Reduce Tracking costs, 20mm thick pads last 50-100% longer at less than OEM pad prices!!
https://www.s2ki.com/forums/"https://www.s2ki.com/forums/"https://www.s2ki.com/forums/"https://www.s2ki.com/s2000/topic/974115-ap-racing-essex-kit-quick-review/page__gopid__21954334#entry21954334""&qu ot;"]SC S2000 Review[/url]
https://www.s2ki.com/forums/"https://www.s2ki.com/forums/"https://www.s2ki.com/forums/"https://www.s2ki.com/s2000/topic/982313-essexurge-ap-racing-kit-review/""""]Dedicated Track S2000 Review[/url]
Wheel Clearance Template (will need BBK friendly wheels) [attachment=23119:Honda S2000 wheel clearance template.pdf]
http://trakplus.com/application"]H&R Spacers[/url] are safe way to widen stance and improve brake clearance
URGE Flow Rear Rotors, 2 piece Vented Rear Rotors $700
Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors-flow-rear-rotor.jpg
  • http://urgedesigns.com/?page_id=1967"]Full Product Details[/url]
  • SIGNIFICANT overall brake improvement due to consistent rear braking power that doest fade
  • Track customers notice Reduce Front Rotor wear, reducing maintenance cost
  • Reduce Rear rotational and unsprung weight by 4 lbs, 2 lbs per side
  • Anodized 6061-T6 Aluminum Hat w/ Spring Clips
  • 282 x16.5mm rotor (same diameter as OEM, doesnt change brake bias, rear brackets need to be widened by 3mm)
__________________
Urge is offline
Old 07-05-2012, 08:08 AM
CD7SirAccord's Avatar
Wow! Great pricing guys!
Please put me down for the brake kit with S100 & C300 brake pads. This will be going on a 2003.
I was also wondering if you guys could get the Spiegler rear brake lines as well to match the front lines?
Thanks!
CD7SirAccord is offline
Old 07-05-2012, 08:25 AM
clarkster009's Avatar
This is a very nice looking kit. Is there any sort of manufacturer warranty?
clarkster009 is offline
Old 07-05-2012, 04:41 PM
99SH's Avatar
Put me down for the BBK with the following pads:
Front RC6 (CP8350)
Front RC5+ (CP8350)
Rear RC5+ (OEM caliper)
thanks!
Arax
99SH is offline
Old 07-05-2012, 06:03 PM
raikouS2K's Avatar
Awesome...hopefully next year I can buy a set of these!
raikouS2K is offline
Old 07-06-2012, 08:48 AM
99SH's Avatar
Originally Posted by Urge
Front RC6 (CP8350)
Front RC5+ (CP8350)
thanks!
Arax
We will get some pricing for you on these Monday.
Thanks, also interested in the rear brake lines as an option. FYI, this is for a MY06.
99SH is offline
Old 07-09-2012, 05:00 AM
Biohazard's Avatar
This looks promising, going to print out the template to see if it will clear the wheels
Biohazard is offline
Old 07-09-2012, 10:33 AM
99SH's Avatar
Originally Posted by Urge' timestamp='1341583226' post='21838299
[quote name='99SH' timestamp='1341535308' post='21837158']
Front RC6 (CP8350)
Front RC5+ (CP8350)
thanks!
Arax
[/quote]
Update in my selection:
AP Racing BBK
Front / Rear lines for MY06
Front DSUNO (CP8350)
Front DS2500(CP8350)
Rear DS2500 (OEM caliper)
Rear DS1.11 (OEM caliper)
99SH is offline
Old 07-09-2012, 10:45 AM
JRitt@essex's Avatar
There is a warranty against manufacturer's defect. In other words, if the kit shows up at your door with a chunk missing out of the caliper, we'll replace it no questions asked. The odds of such a thing happening are highly unlikely as all parts are inspected in England at AP prior to shipping, and at Essex in NC prior to leaving our facility. Other than that, there isn't any coverage against wear and tear, etc. as these parts are considered as being "for off-road use only." It's a fairly standard aftermarket warranty to make sure the parts reach your hands as they were intended to be from the factory.
All of that said, we (Essex & AP Racing) commonly jump through hoops to make sure our customers are satisfied. We will do everything we can to make sure you get the product you expect and the answers you need. I'm sure Urge will do the same.
JRitt@essex is offline
Old 07-09-2012, 10:57 AM
Thanks!
Developing rear SS lines. I would estimate a few months.
Sounds good.
Any idea when you guys will start taking payment?
Thanks,
Jason
Quick Reply: Ohlins DFVs w/ NEW "R" Option! & TTX, Essex/AP BBK & Lightest Vented Rear Rotors
