Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
Password:JDM Dry Carbon Products - ON SALE!
Old 09-08-2008, 05:18 PM
Former Sponsor
GoTuningTommy's Avatar
Default Password:JDM Dry Carbon Products - ON SALE!
Go Tuning Unlimited is now an Authorized Password:JDM Distributor
We have almost all the Password:JDM S2000 products IN STOCK!
PRICE MATCH GUARANTEED!
7/12/09 - Password:JDM Billet Aluminum Battery Stays NOW AVAILABLE!
4/23/09 - Password:JDM 2-point solid strut bar that clear PWJDM intake kits are now available!
1/13/09 - NEW PRODUCTS FROM PASSWORD JDM - Dry Carbon Canards for AP2 Front bumper!
Battery Tie Down
2-Point Front Strut Bar
Street Canards
Race Canards
Password:JDM Dry Carbon Ram Air Intake Kit Also available in Carbon Kevlar
The PWJDM S2000 Dry Carbon Ram Air Intake system produces 11.6rwhp at peak and approx. 12.5rwhp at mid range(4000rpm), it is everything you want for an intake system and all for under a grand! The entire system only weighs 1.8kgs/3.9lbs (stock air box weighs 4.4kg/9.7lbs) making this the lightest and strongest carbon fiber intake system on the market. Made entirely of Dry Carbon, the PWJDM intake system is a combination of individual components designed to work flawlessly with one another. Designed to ram/force feed colder atmospheric air into your engine at all speeds, the PWJDM S2000 Dry Carbon Ram Air Intake system has it all when it comes to what you want from an intake system. All hardware required for installation is included.
Dyno proven performance!
Password:JDM Dry Carbon Ram Air Intake Snorkel for OEM Airbox
Enhances the abilities of the stock intake box. The PWJDM Ram Air Snorkel scoops in cold air from in front of the radiator. Your engine will be happier breathing this cool air, and when your engine is happy; it gives you more power.
- Scoops cold air into airbox
- Super light dry carbon
- All hardware included
Password:JDM Dry Carbon Cooling Plate Also available in Carbon Kevlar
Designed to work with the Password:JDM Ram Air Intake Kit or Ram Air Snorkel. Keeps the engine cool by diverting outside air to the radiator for more efficient cooling.
- Easy install
- Super light dry carbon construction
Password:JDM Dry Carbon Engine Heatshield Also available in Carbon Kevlar
Shields the intake from the engine block to prevent heatsoak of the intake chamber.
- Easily Installed
- Super light dry carbon plate blocks heat from front of engine bay
Password:JDM Header Heatshield
PWJDM Carbon Fiber Header Heat Shield keep the engine bay cool by deflecting heat from the header.
- Easily installed
- Super light dry carbon fiber plate blocks heat emitted by the header
Password:JDM Dry Carbon Complete Underbody Diffuser Also available in Carbon Kevlar
- Increases down force = better grip and control
- Less Undercar turbulence/lift = greater efficiency and stability
- Optimal 3 element rear diffuser design
- Compatible with most exhausts systems including stock OEM
- 100% Dry Carbon vacuumed construction using Aerospace grade Carbon material and Epoxy Resins
- 100% MADE IN THE USA in house by PASSWORDCOMPOSITES
- Strategically placed cooling scoops and NACA duct for adequate cooling of components
- No cutting or drilling of vehicle (trimming may be necessary to fit with a/m ladder bars and braces)
- Installs in 2 hours or less depending on skill level
- Removable sections for ease of maintenance (front section can be removed and re-installed in 5 mins)
- Comes complete with all mounting hardware, braces, and brackets
Password:JDM Hood Dampers
Available in Satin Black or Polished Stainless
What makes the PWJDM hood damper better than anything else out there is that this damper is designed especially for everything from a stock heavy metal hood, to a featherweight CF hood. How is this possible? With the PWJDM hood damper, you can adjust down the pressure within the damper itself! The pressure relief valve is integrated to reduce the excessive amount of charged gasses for applications such as CF hoods that don't require the same amount of lifting force as a stock metal hood. What this means to you is that you won't eventually overstress and crack your expensive CF hood. It always happens with other dampers offered by everyone else.
Password:JDM Dry Carbon Fiber Fuse Box Over-Cover 00-09 S2000
Available in Dry Carbon or Dry Carbon Kevlar
Part of modding your car is making it look good, and looks weren't really a concern when the engineers were designing your ride. It's easy to see that when you open up the hood and it easily looks like a rat's nest. Password knows that looks on the outside don't mean squat if you can't show off what's under the hood. The Password:JDM dry carbon fiber fuse box over-cover for the 2000-2009 Honda S2000 adheres to your stock fuse box cover and will help clean up the look of your engine bay making your engine stand out, while adding a much needed accent to the scene. Like all of our dry carbon fiber parts that we manufacture, this piece has been precision crafted for a perfect fit and requires no tools or modifications to install. We also use a fade-resistant resin during the manufacturing process which ensures that the part will look as fresh as it did and function as well as the day you bought it.
Note:The Password:JDM Dry Carbon Fiber Fuse Box Over Cover fits over the factory part and is adhered with double side tape.
Shipping/Insurance Info:
- Shipping cost will be determined by location.
- Insurance will be included on all orders.
- Shipping to Canada, Hawaii, Alaska, or international. Please PM me for shipping quote.
- For local pick up please PM me. We are located in Orange County, CA.
- The product(s) will be very well packaged.
Payment Info:
- You can order by phone, email, PM, or through our website at gotuning.com
- We accept Visa, Mastercard, Discover, Paypal, Cash, Bank Cashier's Check.
- All order MUST be shipped to billing address or confirmed address for paypal.
- Paypal payments can be sent to paypal@gotuning.com.
- 8.75% Sales Tax sales tax is required for all sales within California.
GoTuningTommy is offline
Old 09-08-2008, 05:38 PM
07GPWvert's Avatar
hopefully ordering mine soon
07GPWvert is offline
Old 09-08-2008, 05:40 PM
Former Sponsor
We got one with your name on it!
Old 09-09-2008, 10:06 AM
tantheman's Avatar
Very cool Tommy and Aaron.
Tan
tantheman is offline
Old 09-09-2008, 10:11 AM
neveronlines2k's Avatar
Thanks for the intake Tommy and the help with the install!!!! Let me know when my cooling plate gets there
neveronlines2k is offline
Old 09-11-2008, 08:48 AM
Former Sponsor
^ you're welcome john!
Old 09-13-2008, 01:11 AM
A51_AP1's Avatar
Any word on that Dry Carbon Driveshaft?
Price on the underdiffuser pleasE?
94402
A51_AP1 is offline
Old 09-15-2008, 08:50 AM
Former Sponsor
^ pm sent!
Old 09-22-2008, 08:44 AM
SICKS2K's Avatar
Has Password JDM made a kevlar version of their header heatshield?
SICKS2K is offline
Old 09-22-2008, 08:45 AM
Former Sponsor
^ yes! We have those as well. Let me know!
Quick Reply: Password:JDM Dry Carbon Products - ON SALE!
