Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Need some coilovers for Spring and Summer? PTUNING has Ohlins, BC Racing , Fortunes and many more!
Old 02-07-2014, 06:39 AM
Former Sponsor
Ptuning's Avatar
Default Need some coilovers for Spring and Summer? PTUNING has Ohlins, BC Racing , Fortunes and many more!
Tax returns are in process. Warm weather should be arriving sooner or later. So why not grab a set of new coilovers for your s2000 . PTUNING has a variety of coilovers just for you! So take a look and let us know which ones you want today
The BR Type coilovers are perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier.
You choose how low or high you want your vehicle, no preset ride height here, and BC Racing's patented concave lower locking ring keeps it locked in. All of their systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Optional adjustable rear camber plates available for most models
- Separate full length height adjustable
- One year warranty
DIGRESSIVE* All Fortune Auto shock absorbers use Digressive piston technology. This technology allows for stiff low speed rebound force which helps give better control of driver inputs such as roll, dive and squat. However, at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
Dyno tested
Mono-Tube damper with high pressure nitrogen
24-step rebound adjustable dampers
Spherical Bearings
IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
T6 6061 Forged & Anodized aluminum mounts and camber plates**
Bright Dip Anodized
Height adjustment independent of pre-load
5 year Manufacturer's Warranty (1 year on piston)
Swift springs upgrade available
Rebuild-able in the USA
Revalve-able in the USA
**Adjustable camber plates are included on MOST vehicle front applications with Macpherson Strut suspension configurations. Please consult our application list for more details.
500 series coilovers incorporate a DIGRESSIVE* piston, 24-step damping, custom rates & a one year warranty
500 Series coilovers are CUSTOM built to order in the USA.
** ETA JUNE ** (if you pre-order, you will receive your ohlins once the new batch is available)
Ohlins Honda S2000 Road & Track Coilovers:
The high-revving, heart-fluttering, screamer from Honda, the S2000 is a sportscar whose engine has a motorcycle’s personality. Winner of many awards for design and engineering, the S2000 is also a trophy winner in SCCA and Autocross, the tuned Öhlins Road&Track suspension gives the driver championship confidence.
This balanced suspension package provides racetrack performance with street comfort, and features conventional shocks both front and rear. Each front shock includes top mount, height adjustor, preload adjustor, length adjustor (15mm lower than stock), single bleed adjustor, model-specific spring rates, and dust covers.
The rear Öhlins shocks each feature a single-bleed adjuster, preload adjuster (approximately 15mm lower than stock), properly rated coil spring, dust cover, and a top mount, as applicable. Both front and rear components have Dual-Flow Valves (DFV) and are light weight, corrosion resistant, fully rebuildable for a lifetime of service, and come with a two-year limited warranty.
MADE IN SWEDEN
Variant 3 race technology for the road with adjustable compression and rebound damping.
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been preset by KW engineers.
Features:
• Independently adjustable damping technology -rebound and compression damping
• "inox-line" stainless steel technology
• Individual height adjustment
• German TUEV-tested adjustment parameters
• High-quality components for long life
• Comprehensive documentation for ease of use
• Infinitely adjustable rebound damping
• 14- level adjustable compression damping
• Unique, independently functioning damping power adjustment
MADE IN GERMANY
*V1, an V2 als available
PM/ or email: abel@ptuning.com for Pricing!
Thanks,
Abel
Ptuning is offline
Old 02-10-2014, 07:45 AM
Former Sponsor
Ptuning's Avatar
Morning Bump! Any questions feel free to PM or call us at 703-257-1728
Thanks,
Abel
Ptuning is offline
Old 02-12-2014, 07:31 AM
Former Sponsor
Ptuning's Avatar
All PM's have been replied!
Ptuning is offline
Old 02-12-2014, 11:00 AM
SuzukaBlade's Avatar
Do you have a set of fortune auto 500's in V5 and in stock?
SuzukaBlade is offline
Old 02-14-2014, 06:06 AM
Former Sponsor
Ptuning's Avatar
PM sent
Thanks,
ABEL
Ptuning is offline
Old 02-21-2014, 06:50 AM
Former Sponsor
Ptuning's Avatar
All PM's replied!. BUMP for friday !!!
Ptuning is offline
Old 02-23-2014, 04:05 PM
bewareofthepoop's Avatar
Shipped 28607 bc coils
bewareofthepoop is offline
Old 02-25-2014, 05:20 AM
Former Sponsor
Ptuning's Avatar
MOrning BUMPPPP!
Ptuning is offline
Old 03-02-2014, 05:38 PM
That_Eggroll_Tho's Avatar
bc racing coilovers shipped to 28212
That_Eggroll_Tho is offline
Old 03-05-2014, 09:44 AM
Former Sponsor
Ptuning's Avatar
BUMP! All PM's replied
Thanks,
abel@ptuning
Ptuning is offline
Quick Reply: Need some coilovers for Spring and Summer? PTUNING has Ohlins, BC Racing , Fortunes and many more!
