Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Insane Brake Deals- Brake Combos From$235
Old 05-21-2008, 05:49 PM
Sponsor
Default Insane Brake Deals- Brake Combos From$235
Hey guys get ready for some great Brake Combos! From Street to Full Race we have a system that fits your budget. Dont miss out these are super red hot and selling out fast! BBK also on sale dont miss out before prices go up!
All brake packages are for front and rear.
Brake Upgrades
Stage 1 Combo
Hawk HPS/ Endless Vita Nuova/ Project Mu B-Force Brake Pads
Gruppe-S Steel Braided Brake Lines
ATE Super Blue Brake Fluid
With Hawk HPS $235 Shipped
With Endless Vita Nuova $305 Shipped
With Project Mu B-Force $325 Shipped
Stage 1 Plus Combo
Hawk HP+/ Endless CCA Pads
With Hawk HP + $275 Shipped
With Endless CCA $445 Shipped
Stage 1 Race Combo
Hawk Blue/ Endless MX 72/ Porterfield R4 Brake Pads
With Hawk Blue $399 Shipped
With Endless MX 72 $599 Shipped
With Porterfield R4 $299 Shipped
Stage 2 Combo
SP Slotted 1pc Rotors
With Hawk HPS $549 Shipped
With Endless Vita Nuova $615 Shipped
With Project Mu B-Force $625 Shipped
Upgrade To Project Mu SCR 2pc Front Rotors for only $650 more!
Stage 2 Plus Combo
With Hawk HP + $589 Shipped
With Endless CCA $735 Shipped
Stage 2 Race Combo
SP Slotted 1pc Rear Rotors
With Hawk Blue $1375 Shipped
With Endless MX 72 $1575 Shipped
With Porterfield R4 $1275 Shipped
SP Rotors
With SP Performance Slotted rotors, you will feel the difference. Its series of slots wipe the surface of the rotor forcing the gases to expel through the slots. The slots also greatly improve wet weather braking by preventing hydroplaning between the pad and rotor. The slots on SP Performance rotors are machined to the minimum thickness. This is done to insure that the rotor strength is not compromised, keeping safety and reliability in mind for virtually all automotive cars and trucks. This is a bolt-on, hassle free way to greatly improve your stopping performance. All rotors are provided with our gray ZRC coating. It provides long-lasting protection against corrosion in the most hostile salt-water environments. After being applied, ZRC provides the highest level of galvanic protection. The film of ZRC is conductive. After the coating heats up during use, it bonds permanently to the metal surface. It will not allow the metal to corrode, even when the surface is scratched.
Pm for Low Price
Powerslot Rotors
Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, our Vac-U-Slot helps push water off the braking surface for better stopping power.
The Vac-U-Slot also serves as a visual wear indicator. The slot is machined to the rotor�s minimum thickness where it crosses the outside edge. If you cannot see the slot along the outside edge, the rotor has worn down to its discard depth.
$345 Shipped - Front & Rear
Project Mu SCR Pro Rotors
Compared to normal steel brake rotors, SCR (Sport Color Rotor) features FCD450 (Dagtile Steel) which exhibits superior durability and stability under all temps. This versatile rotor is designed to be compatible with a wide array of sport brake pads. Whether on the street or track, SCR has been proven reliable under diverse driving conditions to include race competition. SCR affords the driver the ability to maintain controlled and predictable stopping power.
$775 Shipped - Front only
Gruppe-S Stainless Steel Braided Teflon Hoses could very well be the easiest and least expensive way to upgrade your braking system. In any braking system there is flex ? in the pedal, in the caliper, but most of the flex is in the hose. Every time you step on your brake pedal, up to 1500 pounds of pressure moves brake fluid from the master cylinder to the caliper. Most of the way, the brake fluid moves through rigid steel lines. Unfortunately, these steel lines cannot complete the journey all the way to the caliper because movement in the line is necessary to connect a non-moving part (the chassis) to a moving part (the brake assembly as attached to the wheel). These connecting hoses are made from rubber and nylon. Even with the nylon braiding inside the hose, when that much pressure hits it, it will expand. This expansion, or flex, weakens the braking system as it allows for loss of energy meant for the calipers. With Gruppe-S Stainless Steel Braided Teflon brake lines, this flex is reduced dramatically ? this means quicker pedal response and shorter braking distances.
The fitment portion of the Gruppe-S Stainless Steel Braided Teflon Brake Line includes an original swivel mechanism that allows for spinning to reduce tangling and decrease chances of breakage. This swivel mechanism can also be securely locked into place as well. Brake hose material is made out of a teflon tubing covered with SUS 304 stainless steel finely knit meshed blades. Additional black clear coating finish for protection against mud, gravel, cracking, and debris. Suitable for all seasons. Match and fitment test performed on each vehicle application to determine optimal hose layout for easy to use, correct installation.
AP1/ AP2
$99 Shipped
Hawk Brake Pads
HPS
Hawk Performance HPS-High Performance Street disc brake pads are designed for sports cars, coupes, sedans and pickup trucks and sport utility vehicles used for high speed driving or that may encounter repetitive heavy braking. Hawk Performance HPS Ferro-Carbon compound brake pads provide advanced braking characteristics to enhance the driving experience. This unique compound combines the safety and quality of aerospace design partnered with the braking technology of motorsports.
Hawk Performance HPS pads offer 20-40% more stopping power and higher resistance to brake fade than most Original Equipment or standard replacement pads. This makes them more responsive and durable than most standard original brakes and makes Hawk Performance HPS pads the first� and least expensive�way to increase the stopping power of cars and light trucks.
As standard brake pads wear, brake dust is released as the friction material wears in everyday braking. Hawk Performance HPS brake pads are formulated to run cleaner and release extremely low levels of dust in normal street driving.
HP+
Hawk Performance's HP Plus disc brake pads are designed for sports cars, coupes and sedans for sport driving in autocross, Solo II and many �track day� applications. Additionally, the Hawk Performance HP Plus Ferro-Carbon compound can take the heat at the track and get you home safely without having to change your brake pads in and out. This compound was designed for the serious street and autocross enthusiast.
Warning! Due to the dramatic friction levels produced by this product to achieve "race-level" braking, rotor wear, noise, dust, and pad life may be affected.
The high friction level of Hawk HP Plus pads will be more responsive than most standard original brakes and their high resistance to brake fade makes them a superb upgrade for high performance streetcars used in competition, for high speed driving or that encounter repetitive heavy braking.
Blue
For over 15 years, Hawk Performance has dominated the racetrack by providing champions with cutting-edge friction materials. Whether you are looking to improve your braking ability during the next lapping day or looking to make your move on the final lap, Hawk has you covered with a wide array of Motorsport Compound Pads.
SPECIAL NOTE: Due to the aggressive nature of the Hawk Performance Motorsports Compound pads, they are not recommended for street use.
Blue 9012 Compound
Temp Range: 250-1,000 degrees Fahrenheit
Torque: Medium to high
Recommended Use: Hawk's most popular Motorsport Compound offers excellent modulation and braking power for a wide variety of applications. Strong initial bite combines with exceptional pedal feel to give drivers confidence during road racing and stage rally events. Also popular with experienced lapping day and driver school participants.
HPS $146 Shipped
HP+ $205 Shipped
Blue $299 Shipped
Endless Brake Pads
Vita Nuova
Endless has produced the Vita Nuova compound for entry-level users who are seeking improved performance while retaining maximum comfort. Designed for everyday street conditions, the Vita Nuova compound is most popular with drivers looking for affordable street performance. The Vita Nuova compound also functions at low temperature while producing minimal noise.
CC-A
The CC-A compound is a ceramic carbon compound that provides maximum pedal feel. We have designed this compound to exhibit little to none of the negative characteristics that ceramic carbon compounds are known to have. Even though ceramic carbon compounds normally have low braking power at low rotor temperatures, CC-A pads can operate at low temperatures while producing minimal amounts of dust and noise. The CC-A pads do all this while still being friendly to rotors.
MX72
Ceramic is known to be one of the most vital and essential compounds which influence braking capacity. Every material has been carefully chosen for the MX72 in order to produce minimal noise and dust while producing high brake capacity during lower temperatures. Braking stability was also improved under higher temperatures while decreasing rotor wear. Pedal feel, which is typically great in semi-metallic material pads, was further improved upon.
[/SIZE]
Vita Nuova $185 Shipped
CC-A $315 Shipped
MX72 $475 Shipped
Project MU B-Force
The Project mu B-Force brake pads are a non-asbestos, economical street-type brake pad with superior initial stopping power. With the clear objective to improve overall performance above that of stock brake pads, the street-type brake pad was developed for street use where initial stopping power and resistance to fading is of prime importance. In addition to reducing brake dust and squeal, these long-lasting pads help keep rotor wear to a minimum. Applicable rotor temperature (F&R) 0-400 degrees celsius.
$215 Shipped
Porterfield R4
R-4 Full Race Compound � Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictably. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, oval track, rally, vintage racing, autocross, club events or professional racing events.
$199 Shipped
Looking to for more stopping power? Check out our BBK.
Endless Mini Six-Pot
324mmx30mm
Designed with compact size in mind, you can upgrade your caliper while still using OE-sized rotors. The caliper is sized small enough to work with wheels as small as 16 inches for sports cars. Of course, inch-up rotor kits are available. The caliper body is lightweight forged aluminum with excellent heat resistance and high durability. Piston diameters are staggered and differ in diameter, creating excellent controllability and even pad wear. Experience confident stopping power with direct pedal force and ease of use.
PM For Price
Stoptech 4 Piston Upgrade
ST-40 four piston caliper black/red/silver anodized
*328x28mm floating front rotors drilled or slotted
*7075 T-6 Billet aluminum hats
*AXXIS Ultimate brake pads
*Requires 17"+ wheels
*Includes front stainless steel brake lines
PM for BEST PRICING in the US!
Spoon Monoblock Calipers
*Includes mounting bracket
*Fits on OEM size rotors
*Works with OEM size brake pads
*Spacer needed, to fit OEM wheels
$1599 Shipped
__________________
- All Items Are Shipped Via FedEx.
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit.
- Any Order Cancellation Will Result In A 25% Processing Fee.
- Local Pick-Ups Available. Please Call For Details.
- No Cancellation on JDM Or Special Orders. No Exceptions!
Gruppe-S is offline
Old 05-21-2008, 06:51 PM
leo520's Avatar
pm 4 price plz
leo520 is offline
Old 05-21-2008, 09:26 PM
AlwaysTopless's Avatar
PMed you about stage 2 plus.
AlwaysTopless is offline
Old 05-22-2008, 06:40 PM
Sponsor
PM's sent
__________________
Gruppe-S is offline
Old 05-22-2008, 08:18 PM
midnightsunset's Avatar
pm price shipped to 92251 for Endless mini 6
midnightsunset is offline
Old 05-22-2008, 08:53 PM
WlSEGUY's Avatar
pm sent!
WlSEGUY is offline
Old 05-23-2008, 06:22 PM
Sponsor
PM sent
__________________
Gruppe-S is offline
Old 05-24-2008, 01:28 PM
Vik2000's Avatar
endless mini six pot shipped to v3k 3w3?
Vik2000 is offline
Old 05-27-2008, 06:16 PM
Sponsor
^^PM sent
__________________
Gruppe-S is offline
Old 05-28-2008, 06:47 AM
bullitt5897's Avatar
endless 6 pot caliper
optional inch up kit
pm price shipped 30071
Thanks,
Mike
bullitt5897 is offline
Quick Reply: Insane Brake Deals- Brake Combos From$235
