Strakes and flaps
Old 01-22-2017, 05:09 AM
garyg4761's Avatar
Default Strakes and flaps
I have a set of rear strakes on my s,attached to these were a set of small rubber mudflaps.I had to remove these in order to install flybikeslee sideskirts,firstly has anyone had these mudlaps,which are honda branded by the way,and secondly were u able to refit them somehow after installing sideskirts,i just removed mine btw.
Old 01-22-2017, 06:20 AM
UK Moderator
lovegroova's Avatar
Everyone should have the mudflaps, they are there for aero or somesuch. you can see the water dripping off them here:
Old 01-22-2017, 11:57 AM
richmc's Avatar
They keep the airflow to the tyres a bit smoother, you know how important the tyres are to the S.
When I got my S one of the front ones was missing, didn't feel right without it.
Old 01-23-2017, 12:54 AM
Irish TuneR's Avatar
JDM ones don't have them just the front ones, i wonder is it due to them being restricted though....
Old 01-31-2017, 07:38 AM
flybikeslee's Avatar
shift the skirts forward a little bit, all the ones i've installed i've never had to remove the flaps
Old 01-31-2017, 11:56 AM
E4RTH WORM JIM's Avatar
/\ what he said
Or you're fitting them backwards
Old 01-31-2017, 12:39 PM
garyg4761's Avatar
While everyone may have the mudflaps,mine are attached to strakes which idont beleive were standard.I would have to screw the self tapper through the skirt and the mudflap if i keep the skirt at full length and the skirt would be totally uneven,ive tried removing the mudflap from the strake,fix the skirt on and then reattach the mudflap but this doesnt work either.Either i have different mudflaps or my mudflaps and strake combo is causing the issue,just to add the mudflaps run along the whole length of the strakes so i might just chop the skirt where the two meet.Moving the skirt forward abit doesnt help and no im not putting the skirts on backwards.
Old 01-31-2017, 10:27 PM
S2000_sam's Avatar
Gary,
A few of the locals to you here in NI have this done. I know some of them are only on this forum periodically. Might be an idea to use the FB page OR......the regular S2000 Cars n Coffee meet. It is on this Monday evening so would probably give you the best opportunity to ask and see how some of the guys have done this.
exalto
13
02-07-2011 11:36 AM
simonprelude
04-22-2010 12:30 AM
Bundle of Mayhem
10-14-2009 03:37 AM
Gaza
03-06-2008 12:27 PM
Quick Reply: Strakes and flaps
