How wide can you go on the s2k?
Width isn't really what the OP needs anyway if he is concerned about strait line traction, width is more for lateral grip which is why I run them (and N/A mind you) A taller 275/40 tire option has a longer contact patch which would be best for strait line. Couple that with the compound I suggested and it will do the trick. A 275/40 or 275/35 if 18's would be a taller overall diameter along with width to get a good contact patch down for all around boosted performance. 255 can work too, its just your going to sacrifice some longevity and temperament in a more aggressive compound to make up some contact patch deficit. I had wheel spin in 2nd gear with my 450whp Supercharged set up with my Kumho XS 295's and sometimes in 3rd gear if the conditions weren't right. If you ran a R comp like an NT01 in a 255, that would be near equivalent to slightly better probably if warmed up properly. But its the street, so conditions are all over the place.
Always have run staggered. Never felt the need to bias the car to more over steer then it already has. I dont run a rear wing on the track either, so added rear tire helps keep the car feeling planted and balanced in the slow and high speed stuff. 14k springs all around, with stock 00-01/CR front sway and ap2 rear sway bar, Bliss
18" x 9.5" +45 wheel is better suited for a 255. You COULD run a 275/35 but probably need a fender pull at that point. 265/35 might be a good compromise. 265 and 275 are oddball sizes, diameter match is going to be off compared to stock. I guess if you don't mind the higher gearing it could work out for you.
some something like this in the back with 275 will fit?
https://www.amazon.com/18x9-5-Enkei-Silver-5x114-3-3798956545SP/dp/B002HLV17Q/ref=pd_sbs_293_3?_encoding=UTF8&pd_rd_i=B002HLV17Q &pd_rd_r=VWA9VZDBCC3Z1CHAPX6E&pd_rd_w=J7a9Y&pd_rd_ wg=plSud&psc=1&refRID=VWA9VZDBCC3Z1CHAPX6E
how about 225 front and 255 rear on these?
https://www.s2ki.com/forums/wheels-t...r-kai-1165935/
will fit with a fender roll?
the front would work great with a 225, the rear with the +38 might be more work to fit, slight pull on the rear to fit a 255. a 245 would be fine, but the 255 is gonna take a little extra massaging and camber. -2 or -2.5 rear, depends on the 255 you throw on.
See below. I have PSS9s in this photo with just under a two finger gap at the fronts and 1 degree of negative camber. i believe my AD08Rs are quite meaty for a 255 but i dont imagine anything else remotely fitting anyway.
The tyre sticks out by 1/2 an inch.
For a normal alignment you have to pull the front fenders even if the car isn't lowered. If you roll the car enough into a corner your fender will catch the tyre.
