Childsy's Blue s2k
Old 07-28-2013, 11:41 AM
Childsy's Avatar
Default Aaron’s RNB S2K
Hi all, Just bought a MY04 Friday having sold my ep3, new to this forum so HELLO! Name:  null_zpsdcffe93f.jpg
Size:  180.6 KB Name:  null_zps1d613c3d.jpg
Size:  212.6 KB Name:  null_zpsedc4397e.jpg
Size:  201.3 KB Name:  null_zpsc858e6b0.jpg
Size:  164.1 KB Drives great, gearbox is awesome and grips very well but have a couple niggles with it though: There is a whining noise when cars warm when the clutch is engaged and accelerating determines how loud the whining is. Sometimes when changing gear there is a small single knock from under the car.
Old 07-28-2013, 11:46 AM
Childsy's Avatar
To add even with car still in neutral when I select a gear it sometimes knocks as the gear engages....
Old 07-28-2013, 12:00 PM
Childsy's Avatar
Originally Posted by Childsy
Hi all,
Just bought a 2004 facelift s2k
Old 07-28-2013, 12:07 PM
aston19uk's Avatar
I'm not sure with the above. Someone will know. But nice colour !
Old 07-28-2013, 12:26 PM
Kanmuri-san's Avatar
Welcome to the forum Childsy.
Nice ride and colour mate.
I can't help you on your problem as I'm new too. But there's a lot long serving s2k members here and very wise with their car knowledge - someone can help you
Good luck!
Childsy's Avatar
Thankyou!
Old 07-28-2013, 12:28 PM
mikefifth's Avatar
Hello and welcome,
Just a suggestion but couldn't the whinning be the common "clutch buzz"?
This may not work but try regreasing the gear selector, theres a thread on here somewhere, easy job and well worth it however I doubt will fix the selection noise. I have it also and I kind of like it!
Hopefully you will find the answer you are searching for.
Childsy's Avatar
Good luck!
Hello there. Thanks alot.
No problem, cheers.
Old 07-28-2013, 01:35 PM
MIP
MIP's Avatar
Whine might be differential (or gearbox). Could try changing the gear & diff oil as a first port of call.
There can be a bit of a thunk from neutral to first very occasionally, that's normal. I've not had it with other gears.
If it's more of a kind of click from the rear, you may need new hub nuts, torqued to the revised (higher) setting.
Old 07-28-2013, 01:40 PM
richmc's Avatar
Oils first, the S has a quite notchy gearbox at best, fresh oil usually makes a difference.
Quick Reply: Childsy's Blue s2k
