2006+ readiness not setting flashpro
Hello all,
06+ Flashpro users, are any of you having or had issues setting readiness monitors? I have 3 not set currently oxygen monitoring, heated catalyst, evape.
I had catalyst and evape not set so I downloaded the newest manager and updated firmware then uploaded a calibration. I have all sensors enabled driven over 500 miles used about 20 gallons of gas and followed monitor set procedure since the last cal upload. Tried brand new sensors before last cal was loaded and 500 miles ago. Can't be sensors thinking something with flashpro.
Am I missing something?
If anyone has experienced this issue and has some insight please reply.
Hello all,
Keep thinking its because no catalyst your wrong! it doesn't matter. Stock ecu and test pipe readiness set's with a defouler (non fouler). It is not "luck". Readiness sets without a catalyst in every other setup I ever ran. Most people that run hondata don't have a catalyst.
Monitors set perfect in 2013 like they should but for some reason they won't set at all for me now and it seems other users as well recently.
Just trying to get to the bottom of it. It's not because no catalyst the community has gotten around that for 20+ years where have you been?
Car is not running a catalyst converter but does have a secondary o2 sensor and test pipe with a non fouler. It has set before on this setup also on my 9th gen, rsx & among most modified hondas not running a catalyst. All sensors are enabled.
I am having the same issue. I have in the stock injectors, stock map sensor, catalytic converter, o2 enabled, and using software V1.9.1. The O2, cat. and evap are not ready (followed the readiness steps in the owners manual). Does hondata have an eta when this will be fixed?
Anyone who is considering buying the flashpro, hold off until hondata fix this problem because your car will not pass inspection in most states.
What are your climate conditions like?
I just bought the car too, and its not passing inspection but its been passing for the last 3 years so not sure what could be the case right now. Wonder why Hondata hasn't done something to force this to pass smh
