AP1 to AP2 rear subframe/suspension conversion?
Old 10-22-2014, 04:47 AM
dan_uk's Avatar
Default AP1 to AP2 rear subframe/suspension conversion?
has anyone changed the rear subframe and control arms to the ap2 setup with the reduced bumpsteer?
any better/ worse?
I have no real problem with the ap1 my cars pretty dialed in right now but it could probably use a new rear subframe with the left rear being crashed about 3 times
I've heard people saying they preferred the ap1 setup
Old 10-22-2014, 11:53 AM
dc50818's Avatar
any better/ worse?
I dont think u would really notice a difference with aftermarket suspension on the vehicle
Old 10-23-2014, 11:04 AM
SC_Highlander's Avatar
I already had the TC Design anti-bumpsteer kit (toe arms) when I did my AP2 conversion. I honestly didn't notice any real difference between the two.
Old 11-11-2014, 04:34 PM
Sylvain2000's Avatar
That is interesting. You make it sound like it was not worth it.
I guess those antibumpsteer makes a good diference then ??
Sent from my iPhone using Tapatalk
Old 11-15-2014, 04:14 AM
Slowcrash_101's Avatar
The biggest and only real difference is that Ap2 the upper control arm mounting points are further apart than on Ap1. This means that the control arm bushings have less force acting on them perpendicular to their normal motion. They did this to minimize toe change in the rear under braking and acceleration. This is why Ap2 seems more forgiving, Ap1 seems sharper. In either case it's a moot point if you have spherical bushings.
Old 11-15-2014, 05:26 PM
Dead Serious's Avatar
I bet this is why the energy/prothane bushings i tried to install today didnt fit the rear upper control arms.
taylor
10-13-2011 04:08 AM
Bullwings
10-14-2010 11:01 PM
tonerockyhorror
06-29-2007 07:38 PM
BAMbam160
03-02-2007 07:48 AM
Quick Reply: AP1 to AP2 rear subframe/suspension conversion?
