going to look at a S2000 tonight
Old 06-25-2015, 02:52 AM
cejsmith's Avatar
Default going to look at a S2000 tonight
I'm going to look at a 54 plate GT tonight and I was wondering if there is anyway of checking the suspension to see if it's all OK . When I last has a S2000 8 years ago , everybody had horror stories of £2k bill if they need to have it adjusted , is it still the same???
Old 06-25-2015, 02:54 AM
BenRNBP's Avatar
The only real way to check the geo bolts is to try and get them adjusted, evidence of a previous alignment would be a good start though.
Old 06-25-2015, 04:09 AM
cejsmith's Avatar
If the bolts are jammed , what is the cost these days.
Old 06-25-2015, 04:19 AM
BenRNBP's Avatar
If you get an S2000 specialist to do it £1500. DIY ~£700 depending on what's seized, what you need/want to replace and what tools you buy (and how many demolition blades you get through)
Old 06-25-2015, 04:47 AM
japcrap's Avatar
The price it will cost will all depend on how many adjustment points are seized. I paid nowhere near £1500 to get 4 of mine replaced.
Old 06-25-2015, 05:35 AM
GreenmanS2000's Avatar
I'd say £1500 involves a lot of labour - my dealer didn't quote much more to replace the lower arms with new OEM ones + all new bolts etc
Old 06-25-2015, 05:44 AM
mikefifth's Avatar
£1500 will be enough to buy a fully pollybush kit / garage labour/ and a geo.
I just had mine all done, came to the tune of:
£400 poly kit
£900 Labout + Geo
Old 06-25-2015, 06:34 AM
I'm not keen on the poly kit as it makes the ride too harsh - I'm hoping for not a lot more I can bet new OEM fitted,...
Old 06-25-2015, 01:28 PM
CynicG's Avatar
Mine was about £1500 for replacing all bushes with Powerflex, sorting out bolts, painting arms, fitting control arms (supplied), fitting new suspension (supplied) and a good fast road set up. I was happy with that.
Old 06-26-2015, 12:08 AM
Gaffa's Avatar
Did mine myself for about £500, but only replaced what was needed with Mugen bushes, so so basically all the ones with adjustment.
and did the geo myself as well following the instructions from Rob.
https://robrobinette.com/S2000Alignment.htm
Well happy with the outcome.
Quick Reply: going to look at a S2000 tonight
