AP2 2005- Drive shaft Play side to side & Noise
Hi all,
I am a personal fan of all the healthy discussions happening in the s2ki forum. Great members and great forums. Kudos guys ! I own a 2005 S2000 94000 miles on it. Stock except for the a competetion state 2 clutch and a lighter flywheel which the previous owner installed.
I hear a noise and I notice a play in the drive shaft when turning side to side. The shaft that's connected to the gear box also rotates/moves side to side when I turn the drive shaft. I have attached a video here for your reference. I am not sure how to troubleshoot this issue.
https://www.youtube.com/watch?v=mAIQyZzKqyE
<iframe width="420" height="315" src="https://www.youtube.com/embed/mAIQyZzKqyE" frameborder="0" allowfullscreen></iframe>
There is no vibration/ noise from high speed driving. Whenever I go off/on throttle, the drive line seems to have that play and it makes that noise. When i engage the gear and try to launch it, there is this play, then the noise along with it, then I feel a hesitation from the drive line before I move. I am guessing mounts are bad.
Also I want to understand if the play in the drive shaft like this is normal ?
<s2kpuddydad> [s2kpuddydad] [S2KPUDDYDAD] <S2KPUDDYDAD>
this may be off topic, but i think you're missing a washer from the prop shaft to the diff.
the rotational play may be normal.... i'll try to check mine tomorrow.
maybe change your trans and diff fluid?
I have this exact same behavior. I don't know if it's normal or not.
While it doesn't seem to cause any driving issues, it's annoying when getting on/off the throttle, and it just does not seem like it's something that should be normal.
Thanks Krenath. Yeah thats what I am planning to do this weekend - trans fluid and diff fluid. Please let me know how it feels in your car. That would be good information to have. Thanks again
