Rebuilding F20C
Rebuilding F20C
Hello fellow members
So I've had issues with engine recently, a weird noise coming from the transmission (which after replacement, the noise remained) and also a noise from the engine, which seems to be the TCT. I replaced it but the noise came back within 2 weeks. My plan is to either replace the engine and get rid of this one, or just rebuild which would seem like a cheaper option. Any inputs?
Also, any shops that anyone would recommend for this?(rebuilding)
Ive already had a bad experience with Forged so I'm not planning on going back there.
I haven't had a bad experience with Trackforged... But every shop seems to have their own rates; sometimes the amount payed isn't worth the final product. Whatever you feel is a reliable place would be my advice.
Try AR auto down in Lake Oswego.
How many miles are on the motor? Have you done compression? Leak down? There wouldn't be a need to replace the motor unless it was immediately necessary, or you were prepping it for boost or similar in the future. What did you replace the original TCT with? another OEM unit? I would recommend the Billman TCT, or many have had success with the Ballade TCT. If you are getting transmission noises, and you have already swapped transmissions, it could be your clutch/flywheel setup causing the noises. OEM clutch and flywheel?
