Platinum vs Iridium
Old 08-12-2016, 01:05 AM
FreshDonny's Avatar
Default Platinum vs Iridium
Giving my car a service this weekend and just deciding on plugs
Is there much benefit in going for Iridium's over the platinum's?
any pro's/con's, what are people here using?
Old 08-12-2016, 01:37 AM
BenRNBP's Avatar
I think the NGK IX are cheaper - really not much in it, tbh I think I'm going standard copper next time around
Old 08-12-2016, 01:50 AM
UK Moderator
lovegroova's Avatar
OEM PFR7G-11S as recommended. Why would you use anything else?
Old 08-12-2016, 03:32 AM
s2konroids's Avatar
Stick to platinum, if you search about iridium I posted a few months ago, in short don't bother unless your highly modified.
Old 08-12-2016, 05:11 AM
Ultra_Nexus's Avatar
The iridium ones are half the price and do the same job as the platinum ones. I ran them on mine and run them on my current F20C. No issues, no misfires so why not.
Old 08-12-2016, 05:25 AM
UK Moderator
lovegroova's Avatar
It's £35.75 for 4 platinum or £29.99 for iridium from Opie, so hardly going to break the bank.
http://www.opieoils....s-ngk-7772.aspx
http://www.opieoils....x-ngk-2667.aspx
Old 08-12-2016, 06:13 AM
Dillon_93's Avatar
Do the platinum ones come pre-gapped?
Old 08-12-2016, 06:16 AM
Chuck S's Avatar
Received 1,134 Likes on 997 Posts
The OEM PFR7G-11S plugs come gapped to spec. That's the "11" in the model number.
-- Chuck
Old 08-14-2016, 08:28 AM
nomadicS2k's Avatar
Go OEM- one of my Iridiums is failing, it's not worth the haasle! Currently trying to sort a misfire with no fault codes being displayed- fingers crossed this is the one!
Old 08-14-2016, 10:46 PM
BenRNBP's Avatar
I had something similar, pretty sure it was a leaky spark plug tube seal that was causing it.
Quick Reply: Platinum vs Iridium
