strange scratching type noise, Bearing?
Old 09-24-2016, 05:53 AM
Define198's Avatar
Default strange scratching type noise, Bearing?
Ok so today i replaced my belt and the two idle pulley bearings as i have had a strange scratching type noise and presumed it was the bearings from one of them, or my belt worn out, after replacing them i still have the noise, does anyone have any idea what it might be?
[media]https://youtu.be/0PQd8g8KqnA[/media]
also to note, since going supercharged car has been overheating (on the dash) once you put your foot down and do some pulls, so i am beginning to wonder if it might be the water pump?
Old 09-25-2016, 03:04 AM
Define198's Avatar
ok so i took the belt back off, and gave the water pump and the rest of the pulleys a bit of a spin, the pump does make a squeek noise when it slows down, but does not feel scratchy when you try and spin it, the rest of the pulleys feel fine with no movement etc.
https://www.youtube.com/watch?v=hOsRBK_OD3c
Old 09-25-2016, 02:03 PM
Booti's Avatar
Alternator bearing maybe?
Old 09-26-2016, 12:25 AM
Define198's Avatar
i did spin it and it sounded fine, unless its something inside the alternator?
Old 09-26-2016, 08:50 AM
Booti's Avatar
Might only show up when under a sideways load from the tension of the belt. Would suggest a stethoscope or screwdriver to the earr next (carefully)
chief_67k
10-07-2013 02:51 AM
Trailerparktrev
08-03-2012 11:04 PM
BodyCest
12-06-2011 06:02 AM
MegaTRon
06-06-2011 03:45 PM
johnny c
10-26-2005 10:52 AM
Quick Reply: strange scratching type noise, Bearing?
