J's Racing Intake Install
Old 12-29-2003, 04:27 PM
Shadow_S2K's Avatar
Old 12-30-2003, 03:51 PM
darkknight1999's Avatar
Pm Turbo_pwr (aka: Dan) He might be able to get you the install directions from J's Racing.
Old 12-30-2003, 03:53 PM
vapors2k's Avatar
Originally posted by Shadow_S2K
max, you can call me up if you need a hand. I need to uninstall mine.
Old 12-30-2003, 05:02 PM
Shadow_S2K's Avatar
[QUOTE]Originally posted by vapors2k
Old 12-30-2003, 05:03 PM
vapors2k's Avatar
[QUOTE]Originally posted by Shadow_S2K
Old 12-30-2003, 05:06 PM
Shadow_S2K's Avatar
Old 12-30-2003, 08:03 PM
moyopoyo's Avatar
max, i suggest removing the front bumper for the install. if you do that, instead of modifying that beam in front of the snorkle or modifying the end of the snorkel, here's what i did...remove the two bolts on each side of that beam that are right in front of the radiator (they'll be black screws). once you do this, you can tilt the beam up towards you, and the snorkle will slide right through. the only difficult part is screwing the two bolts on the passenger's side of the beam in. it can be done if you don't have too big of a ratchet.
i'm in the middle of installing mine right now, and i've only got the snorkle part bolted in.
if you figure out how to get the little (forgetting the term right now ) thing that the hoses connect to that screws onto the subframe bar with that spacer provided, please let me know. after i get that, attaching the rest will be easy, and then i'm just onto cutting the hood.
edit: i got the bolt in
Old 12-30-2003, 08:11 PM
Shadow_S2K's Avatar
Thanks for the andvice man Hope it all goes well for you
Let me know how it goes when your done. Thanks
Old 01-05-2004, 10:36 PM
Shadow_S2K's Avatar
Hey, I did the install, everything works and fits pretty good. The only problem is my VIS J's style hood won't close! Anyone else have a similar problem or sudgestions? Thanks
Old 01-05-2004, 10:39 PM
moyopoyo's Avatar
have you cut your hood yet?
Quick Reply: J's Racing Intake Install
