Vancouver BC S2000 Owners Meet fellow owners in the Canadian province of British Columbia.
Changed Diff and tranny fluid
Old 01-06-2010, 06:00 PM
XtC-604's Avatar
Default Changed Diff and tranny fluid
Makes a world of difference. My lever was getting notchy so i got some Honda MTF3, changed out the tranny fluid. While i was at it, got the Diff fluid changed as well to Motul 75w90. And OMG the diff fluid smells BAD. A few things i found interesting on the subject. I had metal shavings on the diff drain bolt. There was 2mm of sludge on the stock magnetic drain bolt. I bought the T1R bolt and the Spoon Set. Looks like quality parts. So enough of the random thoughts, point is change your fluids guys makes a world of difference
Old 01-06-2010, 06:46 PM
taki's Avatar
I am going in for oil, transmission and diff. fluid change as well on monday. I will be using all Motul fluids and getting all the magnetic drain bolts as well. I was not sure of the magnetic bolts but since you mentioned you had some metal shavings . It does sound like a good idea.
Old 01-06-2010, 07:29 PM
OTL
OTL's Avatar
what's the regular maintance interval for tranny and diff fluid?
i just change my tranny fluid every 20000km - done it twice
and diff fluid every 10000km - done it 4 times
i also found metal shavings on diff bolt magnet every time i opend it.
where did get the t1r diff bolt and spoon set and how much?
Old 01-06-2010, 08:44 PM
alSpeed2k's Avatar
Is the stock diff bolt magnetic? OTL, you can get T1R and Spoon stuff from A&J racing. I bought all the fluids already too, but I've been too lazy to change it. Hopefully I'll get around to it next week.
Old 01-06-2010, 08:51 PM
Chow-bot's Avatar
i got the spoon bolt set from A&J.
i got my fluids changed last summer, made a big difference
Old 01-06-2010, 09:42 PM
ohkun's Avatar
that would be my current tranny?
happen to know what km did you change at? so I know when to change next?
thanks!
Old 01-06-2010, 09:46 PM
Chow-bot's Avatar
probably only about 5-7k since it was changed
Old 01-06-2010, 10:03 PM
XtC-604's Avatar
K guys, i got everything from AJ-Racing. The stock diff bolt is magnetic. Interval for manual transmission fluid change is supposedly every 60,000 but i would do it every 20,000 or less depending on what season. IE summer i would change it more just cause i'm more aggressive. The Spoon bolt set that chowbot and a few other of us have bought contain two bolts. One tranny and one engine oil. The diff fluid is every 90,000 in honda books i believe...but s2000s have shitty ass pumpkins so i'd probably change it every time i change tranny fluid as well. Motul gear fluids are better than the previous stock stuff i had in the car before though, car is quieter, and maybe a placebo effect but my butt dyno says that its smoother and just got a lil bit more pick up.
Old 01-06-2010, 10:19 PM
ss04's Avatar
Changing Tranny and Diff fluid is always good
I do mine every year regardless of how many km's I drove it. Call me crazy but I think some of you may be just as crazy
Old 01-06-2010, 10:38 PM
Chow-bot's Avatar
i will go on a limb and call you crazy cam
Quick Reply: Changed Diff and tranny fluid
