The "pipe bomb" solution works to disable TPMS!
Old 01-24-2010, 04:40 PM
Gernby's Avatar
Default The "pipe bomb" solution works to disable TPMS!
My previous car was an '06 Lexus IS350, and there was a HUGE need to disable the TPMS error when aftermarket wheels weren't compatible with it. Someone found that you could build an air chamber (pipe bomb) to house all 4 OEM TPMS sensors, pressurise it, stick it in the trunk, and the TPMS would be happy.
I couldn't find anyone who has tried the same on an S2000, so I gave it a try, and it worked! No more TPMS light!
BTW, I tried leaving one of the screw caps unglued so that I could have easy access to the TPMS sensors without destroying the chamber, but it was not possible. I tried teflon tape and teflon paste, but I couldn't achieve a seal that would maintain 35 PSI for any period of time. I had to glue everything.
Old 01-24-2010, 07:03 PM
justind's Avatar
your miesters dont work with the tpms?
Old 01-24-2010, 07:18 PM
Gernby's Avatar
Nope.
Old 01-24-2010, 07:30 PM
crank's Avatar
haha ingenious !!
Old 01-24-2010, 08:55 PM
CKit's Avatar
That's pretty smart! I wonder if you could find a small go-kart tire or something similar to house the sensors. I just leave the light on and ignore it during snow tire season.
Old 01-24-2010, 09:09 PM
cenix's Avatar
my tpms are so temperamental anyways, even though my pressures are good they come on and off whenever they please. i think i should get the dealer to reset them or check them. worthless buggers.
Old 01-25-2010, 04:03 AM
dammitjim's Avatar
[QUOTE=CKit,Jan 24 2010, 11:55 PM] That's pretty smart!
Old 01-25-2010, 05:45 AM
Gernby's Avatar
I read that some people used wheel barrel (wheel burrow?) tires, but I thought that would be more expensive, and maybe even more difficult.
Regarding the termpermental sensors, I would be surprised if there wasn't some sort of initialization / calibration procedure in the owner's manual. My Lexus had it.
Old 01-25-2010, 09:40 AM
CKit's Avatar
Barrow...
I'm bumming that I gave away all my HF autocross trailer tires.
You could probably find used lawnmower / snowblower wheels at the local junkyard. Not sure if they'd take that kind of psi, though.
Old 01-25-2010, 11:13 AM
AngryTurtle's Avatar
I would think the pvc method would be more compact and just generally easier the a small tire.
Quick Reply: The "pipe bomb" solution works to disable TPMS!
