75mm testpipe availability?
Old 06-18-2011, 12:31 PM
08s2000CRbackinblack's Avatar
Default 75mm testpipe availability?
are there any companies which made 75mm testpipes? ive searched ebay an didnt have any luck. i dont want to but a 70mm on which would create gas flow turbulence. regular 3" flanges arent shaped the same as the flange on the end of a testpipe so does anyone make/ or can make a 75mm testpipe? thank you very much for any info you may be able to helop me with!!!!
Old 06-18-2011, 12:37 PM
Luis06s2k's Avatar
Search "Asura" on this forum... They should carry it ... If not be able to make one for you.
Old 06-18-2011, 12:57 PM
slowd16's Avatar
Just find an exhaust shop local to make one.
Old 06-18-2011, 01:21 PM
yes i just found a post the asura can make one. i have plenty of 3" flanges but none the match the shape of the flange used to bolt up to the stock cat as this sytem was designed to. many exhaust shops dont use SS either. i wonder how much asura charges for their testpipe? im suprised more companies are making these like invidia
Old 06-18-2011, 06:21 PM
whiteflash's Avatar
Asura
Old 06-19-2011, 04:49 AM
slo ap2's Avatar
ultimate racing also makes a 3in. testpipe too. That's what I'm running now.
Old 06-19-2011, 07:05 PM
H22toF20's Avatar
I originally ran a UR 3" test-pipe with my HKS 75mm and it didn't fit worth crap. I ended up going with a Hytech 3" test-pipe through GTmotoring(designed to bolt to an OEM like header).
Old 06-19-2011, 09:21 PM
slo ap2's Avatar
suppose they are hit or miss then. I don't have any issues with mine.
Old 06-20-2011, 11:26 AM
H22toF20's Avatar
Originally Posted by H22toF20' timestamp='1308539147' post='20699175
[quote name='slo ap2' timestamp='1308487796' post='20697600']
[/quote]
The angle it mounted to the OEM manifold was VERY bad. I actually did run it for 3 months with zero leaks though. Once it started leaking I opted for the Hytech. I didn't even try selling the UR, I just scrapped it.
Old 06-20-2011, 04:53 PM
i just orderded the UR and they are special making it to my order so hopefully it will fit perftect, if not i will modify it to fit perfectally. asura said they dont make they testpipe and only the resopnated version =( i will be receiving the UR testpipe wednesday so i will let you know how it goes. thanks giuys!!!!
Quick Reply: 75mm testpipe availability?
