DIY Fixing the AP2 Center Console Cup holder
Old 12-17-2012, 10:18 PM
boyguan's Avatar
Default DIY Fixing the AP2 Center Console Cup holder
I had this pop up holder broken on my car for a while and i really needed to fix it as my coffee kept moving around. I know most of us dont use this to hold drinks but on those certain occasions, it does come in handy.
Starting off you need to make sure that the two holes on either side of the divider are still there and not broken. Next you want to check to make sure the holder to hold it down is still there otherwise it wont stay down. It will still remain up which is fine for me.
[attachment=31736:image_3.jpeg]
Step one make sure you order the part which includes the divider and the spring as they seem to know we will need it. PN 77231-S2A-A52ZA. Once you have the part start by putting the spring into the divider like shown so that the spring will sit like shown.
[attachment=31734:image_1.jpeg]
[attachment=31735:image_2.jpeg]
[attachment=31737:image_4.jpeg]
ok now its time to remove the center console. There are may write ups for this but pretty much you remove the shift knob and pull up on the edges of the center console until it pops out. Next you unplug the switches and remove. Good time to grease the shifter if you like and to adjust the brake.
What i did was remove the actual cup holder from the console by removing a few screws so i had more room to work with but unnecessary.
Now comes the tricky part. The divider is slipped in from the back and pops into the two holes on the side. What you need to do is bend the spring so that it is under tension kind of like a clothes pin. Once you slip it in you can release the pin. It was tricky at first but i think you can figure it out. I didnt try it but i think you can use some scotch tape to hold it back and push it in. Someone try it and see if it works.
[attachment=31738:image_5.jpeg]
[attachment=31739:image_6.jpeg]
[attachment=31740:image_7.jpeg]
Once you put it in you should be able to slightly align the spring again so that it sits in the groove.
Reassemble and enjoy your working cup holder again
Attached Thumbnails DIY Fixing the AP2 Center Console Cup holder-image_1.jpeg   DIY Fixing the AP2 Center Console Cup holder-image_2.jpeg   DIY Fixing the AP2 Center Console Cup holder-image_3.jpeg   DIY Fixing the AP2 Center Console Cup holder-image_4.jpeg   DIY Fixing the AP2 Center Console Cup holder-image_5.jpeg
DIY Fixing the AP2 Center Console Cup holder-image_6.jpeg   DIY Fixing the AP2 Center Console Cup holder-image_7.jpeg
The following 2 users liked this post by boyguan:
kasher_khan (01-07-2018), Kass.s2000 (01-03-2020)
Old 12-18-2012, 07:58 PM
RacerXI's Avatar
Thank you sir.
Old 12-18-2012, 09:37 PM
Arthas's Avatar
Wow, I'm going to do this next, Maybe while I have the center counsel out I will find out Why my door opens very slow
Old 12-18-2012, 11:37 PM
darkfalcon's Avatar
Nice write-up. Always good to see more how-to's popping up
Old 12-18-2012, 11:39 PM
MBHs2k's Avatar
Nice. It took my dad and I quite a while until we got the spring to sit right.
Old 12-18-2012, 11:59 PM
boyguan's Avatar
Probably the track dirty or the spring is dirty
Old 09-15-2013, 08:59 PM
JOS2000's Avatar
Nice write up! thank you!
Old 09-16-2013, 05:59 AM
cosmomiller's Avatar
Received 1,568 Likes on 932 Posts
and for something for that won't interfere with shifting:
Old 09-16-2013, 09:12 AM
iamxpl's Avatar
i just cant do it. i cant have any drinks in the S. not that im anal about being clean. i just dont have the time to drink while driving the S.
Old 06-26-2014, 06:55 PM
Tm410s2000's Avatar
First post on the forum since I got my (second) s2k. Thank you for this fix! Now anybody want to buy this ap2 console I just fixed? Lol (car is ap1)
Quick Reply: DIY Fixing the AP2 Center Console Cup holder
