Συμπεριφορά Συζητηση σχετικα με τη συμπεριφορα του αυτοκινητου, οπως ευθυγραμμιση, αναρτησεις, φρενα, ελαστικα ζαντες και βελτιωσεις
Click noise from the back
Old Oct 31, 2006 | 11:48 PM
waterscorpion's Avatar
Default Click noise from the back
Hi everybody
worry about this noise it is coming from the rear wheel like a click only when i launch the car from a standstill, so did anyone of experience the same noise and what was the problem and how to solve it.......??
thanks
Old Nov 1, 2006 | 12:48 AM
ThanasiS2K's Avatar
I also have the same clicking noise.I dont know what it is,but its coming from the rear left brake.I have new brake pads.Have you recently change yoy rear brake pads ?
Old Nov 1, 2006 | 02:19 AM
Taseas's Avatar
Have you removed the rear wheel recently? If that's the case you need to go and have it tightened a bit!
Old Nov 1, 2006 | 03:00 AM
taz5's Avatar
Tighten the axles from both sides and you should be ok.
Old Nov 1, 2006 | 03:20 AM
YiorgoS2k's Avatar
It's the rear wheels' hub nuts that have to be tightened or even better replaced and retorqued @ 220lb/ft.
https://www.s2ki.com/forums/index.ph...ic=142394&st=0
And here are the revised Honda nuts with more thread to eliminate the problem.
http://www.hardtopguy.com/store/product.ph...3&cat=56&page=2
jezzder
Apr 4, 2009 08:57 AM
KerryF
Apr 2, 2007 04:50 PM
waterscorpion
Nov 14, 2006 09:02 PM
MB
Aug 9, 2006 10:40 AM
joper90
Sep 13, 2005 12:54 PM
