Squealing
Old Apr 2, 2007 | 05:30 AM
KerryF's Avatar
Default Squealing
My car started making a squealing noise this weekend. It sounds very similar to a low brake pad noise on an warped rotor. But it only happens at low speeds when coasting, and only after a bit of driving. Doesn't matter if the brakes are applied or not.
Something makes me suspect a wheel bearing, sounds like it's coming fromthe drivers side rear. But all the bearing noise I've had in other cars increases with speed and is always present.
Any ideas what it might be?
Old Apr 2, 2007 | 09:59 AM
KerryF's Avatar
Also, I should add that I don't believe it's the pad because it doesn't happen at all when I first start driving the car, and it makes the noise when I'm not applying the brakes.
Old Apr 2, 2007 | 12:16 PM
yosephs2k's Avatar
does it get a bit louder when u turn the car at slow speeds and when coming slowly to a stop?
i kindof have the same symptoms
Old Apr 2, 2007 | 04:36 PM
KerryF's Avatar
Well I torqued the rear axle nuts to 220 ft lbs and it seems to have gone away. I hope the bearing wasn't damaged too badly.
Old Apr 2, 2007 | 04:50 PM
Slows2k's Avatar
You may want to check the rear brakes pads just to be sure.
WarrenW
Oct 28, 2017 08:21 AM
jdmfbpsi
Sep 30, 2011 05:37 PM
JoJa15
May 8, 2010 11:25 PM
boosted_ap1
Apr 18, 2008 05:58 AM
Jefferson D'arcy
Mar 21, 2006 12:14 PM
