Alabama S2000 Owners Club Areas including Huntsville, Birmingham, Florence, Decatur, Anniston, and Tuscaloosa
VTEC Problems
Old Mar 15, 2008 | 08:36 PM
HS2K007's Avatar
Default VTEC Problems
My Check engine light came on today when I was in fifth gear and the car felt like it geared down as if it over revved when it is cold. I had been driving all day, so I know that the car was not cold. It had been feeling like the car would miss fire un hard accel, but only in the upper rpm ranges. I thought maybe i needed to change plugs, but the car runs fine at lower rpm and speeds. What do you guys think, VTEC valve solenoid or something else?
Old Mar 15, 2008 | 09:25 PM
Jql168's Avatar
Air filter. Oil Level.
Check them both and Vtec should kick correctly
Old Mar 16, 2008 | 04:42 AM
em ekohc's Avatar
Check your oil level, Have you gotten the code pulled yet?
Old Mar 16, 2008 | 07:23 AM
RBC3's Avatar
Was the CEL solid or blinking?
Old Mar 16, 2008 | 08:16 AM
HS2K007's Avatar
solid
Old Mar 16, 2008 | 09:03 AM
RacerXI's Avatar
Check your oil.
Old Mar 16, 2008 | 10:07 AM
Slows2k's Avatar
check the oil, then get the code pulled
Old Mar 16, 2008 | 01:16 PM
ROLLINS's Avatar
If all else fails, take your cat off and make sure it's still in one piece.
Old Mar 16, 2008 | 05:58 PM
HS2K007's Avatar
oil fixed it, how do i reset the code?
Old Mar 16, 2008 | 06:05 PM
Slows2k's Avatar
Remove the back-up fuse.
Check your oil when you fill up for gas
