changing engine air intake filter
4 Attachment(s)
OK.....S2000 friends.... I want to change my S2000 engine air intake filter..... can someone please tell me step by step how it's done. What tools do I need?
See the attached pictures .... Thanks. Little Red |
Doesn't look too dirty. Pull up on the plastic divider. It slides right out. Then pull the air filter off. Might have to wiggle it but it pulls right off.
4 Attachment(s)
Originally Posted by little red
(Post 22789547)
See the attached pictures .... Thanks. Little Red OK ... i have a 2006 S2000 .... I reopened the air cleaner cover... I then lifted the the air cleaner element out of the star slot it was pressed into. Next I lifted the air cleaner out of the air cleaner case. All I have to do now is remove the Air cleaner element from the air flow tube... I believe the the spring on the air flow tube is holing it in place. When i get the new OEM honda air cleaner element I will try to install it by moving the spring on the air flow tube. ( see attached pictures ) I think I have this right ? If not then please let me know S2000 friends. Little Red |
Originally Posted by HannibalACP82
(Post 22789568)
HannibalACP82, thanks for your help..... But, As you can see from the pictures I posted the plastic divider on my air cleaner case is not removable. The air cleaner element I believe is held on with the air flow tube spring.... I will try and take off the spring today to release the air cleaner element. I will keep you posted. Little Red |
You don't have to do anything with the spring. Just wiggle the old filter out and push the new one in.
Originally Posted by onu2002
(Post 22790933)
Hello ONU2002, thank you so much ..... You provided the answer I needed.... I will be picking up the air cleaner element on Tuesday.... I will install it as soon as I get home. Thanks again , it is certainly appreciated by me. Little Red |
(Post 22790587)
Engine Air filter element is installed..... No problems at all...... Thanks to HannibalACP82 and ONU2002 for your input. It was
(Post 22798771)
