Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
clutch advice needed
Old Nov 8, 2013 | 01:51 PM
jbuddycool's Avatar
Default clutch advice needed
So after changing my clutch master and slave ive determined that the clutch needs to be changed. I have been shopping around and found a good deal from THMotorsports. my question is, is this a good clutch or is it garbage?
https://www.s2ki.com/s2000/topic/997...8%85%E2%98%85/
Old Nov 8, 2013 | 03:31 PM
MikeysFC's Avatar
Can't speak for what you've linked, but, I've heard great things about the SoS clutch kit. It's what I'll be going with when it's time: http://www.scienceofspeed.com/produc.../Sport_Clutch/
Old Nov 8, 2013 | 05:01 PM
jbuddycool's Avatar
I also need to consider stage 2 or 3
Old Nov 9, 2013 | 08:23 PM
s2k4life_az's Avatar
Exedy Stage 1 or 2. TH is a good place to buy. I bought my last clutch and flywheel from them. Good price and quick shipping.
Old Nov 9, 2013 | 08:49 PM
xeuxx's Avatar
How about some additional information on your power levels and if you care about a stiff pedal or not.
Old Nov 10, 2013 | 10:54 AM
jbuddycool's Avatar
right now it is N/A w/ intake. my next purchuse will be new headers and exhaust. then I plan on installing a NOS kit
Old Nov 10, 2013 | 03:21 PM
Boofster's Avatar
I would do Centerforce up to about 300 ft/lbs of projected torque but it's also on the expensive side at ~$750.
Boris said his Clutchmasters FX300 (Stage 3) is very good for a higher grip clutch.
Old Nov 10, 2013 | 04:59 PM
jbuddycool's Avatar
My budget is very limited so i found the deal by a sponsor for the flywheel (w/ new bolts), stage 3 clutch kit, both bearings, and alignment tool for $675, im trying to find out if competition clutch is a decent brand.
Old Nov 10, 2013 | 05:19 PM
Boofster's Avatar
You should mention you're limited on budget because that usually changes everything.
Old Nov 11, 2013 | 02:37 PM
Feezy's Avatar
If you're N/A the Mugen pressure plate and the OEM disk is supposed to be an excellent combo.
OEM feel with better better grab. When I need a new clutch I'm pretty positive that's what I will be going with. It'd not the cheapest set up in the world but if you can hold out a few months it's more than worth it.
