Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Need a TPS Sensor
Old May 30, 2007 | 06:42 AM
Zacreth's Avatar
Default Need a TPS Sensor
Hey I'm looking to see if anyone knows of a person that is parting out their car by chance or have a hookup where I could get a Used TPS sensor or hell even a cheap new one.
Can't get the part from Honda unless you order the damn TB assembly so any help would be great.
Zac
Old May 30, 2007 | 10:16 AM
duality's Avatar
Every time I see this topic all I can think of is Bill Lumburg asking if the TPS reports are done. haha
sorry that I'm no help.
Old May 30, 2007 | 10:34 AM
1FastS2k's Avatar
Yeeaahhh, Uummmm I'm going to need those TPS report and Ummmm I'm going to need you to work this weekend, Yeeaaaahhh.
Seariously though, Try http://www.haprecycling.com/ . They aren't local, but they always have a few S2ks around.
Old May 30, 2007 | 10:50 AM
Zacreth's Avatar
Thx for the info I'll give them a call later and see if they have that part.
Old May 30, 2007 | 11:18 AM
WLAURENT's Avatar
The only source for the TPS is used or buy the complete TB from Honda.
You can find them on ebay: http://motors.search.ebay.com/honda-TPS_W0QQfromZR40
I believe that most all of the Honda TPS are the same.
Old May 30, 2007 | 03:37 PM
Zacreth's Avatar
Is that true that almost all the TPS sensors from Honda are the same??
Anyone else know about this or what are compatible with the S2k?
Old May 30, 2007 | 04:45 PM
Boofster's Avatar
I have a GSR manifold with the TPS still intact (I think). Gonna check if it's the same later. You can have it if it is.
Old May 31, 2007 | 06:42 AM
Zacreth's Avatar
That would be awesome if it was the same. I'll buy ya some beer for it...lmao
Old Jun 14, 2007 | 08:00 PM
Zacreth's Avatar
OKay my car is really shitty right now and need a new sensor asap. It's stalling at almost every red light. If anyone have any leads on how to get a new sensor without buying a complete Throttle Body from the dealership would be great.
Old Jun 14, 2007 | 09:22 PM
WLAURENT's Avatar
I really doubt it is your TPS.
Did you try the MAP whack? Could also be your IAC valve.
I was having some idle/low RPM issues and found that running some fuel cleaner followed by some octane boost for a couple tanks helped.
I have an extra MAP sensor and IAC valve if you want to stop by my house on Saturday to try them out. Will make you a good deal on either if they fix your problem.
The TPS will typically not effect your idle unless it is not reading correctly at off throttle. I can also check your TPS operation to verify its operation if you come by.
