Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
NOOOOO
Old Oct 12, 2010 | 01:53 PM
boy blue11's Avatar
Default NOOOOO
My check engine came on yesterday when I started my vehicle. I went to autozone and they checked it and they said the computer says its a cylinder 1 misfire. Any suggestions? any mechanics? I have 85k 2004
Old Oct 12, 2010 | 01:55 PM
adrs2k's Avatar
You can check your spark plug. If it looks ok, try swapping coilpacks. If the misfire moves to another cylinder, then it is the coilpack that has gone bad.
Old Oct 12, 2010 | 02:17 PM
9kred's Avatar
Old Oct 12, 2010 | 04:32 PM
ZeroF's Avatar
I hope for your sake its something easy like the spark plug or coilpack.
My best wishes and thoughts are for you and your motor.
Old Oct 12, 2010 | 04:35 PM
9KRDLIN's Avatar
Common problem is the vlave guides on your year, however, it is also the last thing to expect. Change plugs, and move that coil pack to a different cylinder. Let us know how it works out for you.
Old Oct 12, 2010 | 04:37 PM
SXY_S2K's Avatar
Check your spark plugs for sure. I have an 03 with 78K and changed my plugs this weekend. Two were at a gap if 1.3
Replaced with favtory NGK's, I think it was $45 OTD for the plugs at Honda.
Old Oct 12, 2010 | 04:52 PM
1FastS2k's Avatar
I'd start with checking the plugs. Then mark the top of the coils (1,2,3,4) and switch them around. If it is still misfiring in the same cyl, it could either be an injector or a valve issue. If the misfire moves to different cyl, it's probably the coil pack. Good luck. My misfire issue was an injector problem.
Old Oct 12, 2010 | 05:38 PM
boy blue11's Avatar
Thanks guys I really appreciate it. I just ordered some iridium spark plugs. I hope that is all I need. I have been good on the motor and dont race so I hope thats the only problem.
Old Oct 13, 2010 | 12:01 PM
boy blue11's Avatar
Do you guys think that pulstar iridiums would be a bad choice over oem spark plugs?
Old Oct 13, 2010 | 12:48 PM
adrs2k's Avatar
I would have stuck with OEM....
Did you inspect your plugs? Or try switching the coils around yet?
