Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Thicker Oil for SC
Old Aug 26, 2009 | 09:24 AM
hazmat's Avatar
Default Thicker Oil for SC
Hi im going to install the VTSC later in the week and possibly change the oil with it. Should I get some thicker oil because of FI? since the charger is a self-lub system and doesn't cause as much heat as a turbo, I want to keep the 10w30 m1 I have been using. Any concerns for that?
Old Aug 26, 2009 | 10:12 AM
1nate7's Avatar
I run Amsoil 10w30 and would recommend it, Redline is also good. Personally I'm not much of a Mobil 1 fan anymore, seems to burn off more than other oil that I've used.
Old Aug 26, 2009 | 10:52 AM
hazmat's Avatar
Where can i get some amsoil? redline 10w30?
Old Aug 26, 2009 | 10:56 AM
KeithM's Avatar
http://www.redlineoil.com/dealers.aspx
https://www.amsoil.com/dealerlocatorresults/
Old Aug 26, 2009 | 10:57 AM
1FastS2k's Avatar
Lopers carries Redline.
Old Aug 26, 2009 | 11:29 AM
skibum's Avatar
You should be able to do 1/2 the install in your living room if you bought a new kit. Assemble the blower and all the brackets where it's nice and clean. What are you using for the oil return?
Old Aug 26, 2009 | 11:42 AM
9KRDLIN's Avatar
We use and recommend Motul
Old Aug 26, 2009 | 12:48 PM
Boofster's Avatar
If it has it's own oil, why even discuss the motor oil?
Old Aug 26, 2009 | 01:36 PM
3en's Avatar
3en
I thought the oil on the VTSC was self contained in the blower unit itself.
Old Aug 26, 2009 | 01:39 PM
hazmat's Avatar
yeah maybe my question is confusing, I was asking to see if I need to run thicker motor oil for an SL SC.
