Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Turn Signal Issues
Old Dec 9, 2009 | 05:55 AM
xeuxx's Avatar
Default Turn Signal Issues
My turn signals and hazards have stopped working.
Things I have checked:
1. All fuses under the dash panel
2. All fuses under the hood.
3. Last local meet I swapped the 2 "Lighting Relays" still no go.
Are there any other relays to try swapping out? Because my hazards and my signals don't work I'm also ruling out the turn signal stalk and the hazard button as variables.
I was considering pulling the battery for 10-15 mins to reset the ECU but didn't think that would help and wanted to avoid ECU learning and crap gas mileage.
Any input?
Old Dec 9, 2009 | 07:50 AM
skibum's Avatar
I want to be the first to tell you that you are out of blinker fluid.
Old Dec 9, 2009 | 07:55 AM
RedChili's Avatar
Look for frayed wires?
Old Dec 9, 2009 | 09:32 AM
CBR2200's Avatar
Probably not your particular issue but I had the same problem. I eventually found it was caused by some crumbs jamming my hazard light button half down.
Old Dec 9, 2009 | 09:41 AM
RogerHinga's Avatar
was it working after you did the ap2 head and tail conversion? i would check the wiring.. maybe something came lose on those end
Old Dec 9, 2009 | 03:19 PM
Zonie's Avatar
By not working you mean they don't engage (no clicking) or there's no light? Not to sound like a moron, but you checked the bulbs right?...
Old Dec 9, 2009 | 04:12 PM
xeuxx's Avatar
I should have mentioned that I checked each bulb.
Also, the green indicators on the dash do not blink either.
Either way I didn't know that there was a designated "Turn Signal/Hazard Relay" under the dash. I only tried the "Lighting Relays" under the hood. Someone posted up all of the wiring diagrams in "Under The Hood" helped me big time.
So next meet gonna try that then I'm sure it will resolve.
Roger, I did the conversion about 8 months ago but ended up going back to AP1 tails and keeping the AP2 heads.
Old Dec 9, 2009 | 04:24 PM
Bryan720's Avatar
Try another hazard button. In a lot of cars if the hazard button is broken the blinkers will not work.
Old Dec 9, 2009 | 07:31 PM
mpetus's Avatar
Flasher is bad. '?'
Old Dec 10, 2009 | 06:35 AM
9KRDLIN's Avatar
your hazard button has failed or has come unplugger. seen it plenty of times. lift up your center console and take a peek
