X-brace install
You can do it from jackstands or with the car on a ramp. Take out the four OEM bolts and then fit up the X-brace. Try and get a couple of bolts in to hold it in place. Then put the other two bolts in and bolt the X-Brace to the car by tightening evenly on the four bolts.
Be a little careful, you don't want to strip the threads in the frame. If your having trouble getting the bolts to thread in, then loosen the other bolts that are holding the subframe connectors, so that you can line up the bolts, subframe and X-brace as close as you can.
I think the final bolt torque is 36 ft-lbs. I used some medium thread lock on the bolts. While your there you just as well tighten up all the other subframe bolts to the same torque.
