Ark-La-Tex S2000 Owners Covering Arkansas, Louisiana, and East Texas
Need some help...
Old Jan 28, 2007 | 10:00 AM
MDS2KAp1's Avatar
Default Need some help...
These are my year model car, and all symptoms that I have.
https://www.s2ki.com/stor/library/TSB/A00-055/index.htm
https://www.s2ki.com/stor/library/TSB/A00-054/index.htm
https://www.s2ki.com/stor/library/TSB/A00-050/index.htm
I think this one has been done, because I have a cut in my carpet
But I do not have a warrenty, is there any way to get these things fixed?
Thanks for the help guys!
Old Jan 28, 2007 | 11:42 AM
The White Mandingo's Avatar
Don't have any of the first two problems but the third one I do have my carpet cut because of that damn problem
Old Jan 28, 2007 | 12:07 PM
icemans2k02's Avatar
same here on the third one. the second one is not from gear lash its the after market clutch. its clutch buzz very common issue when you get new clutches and flywheels
Old Jan 28, 2007 | 12:11 PM
and 2 gear is prolly deff the synchros going out
Old Jan 28, 2007 | 12:42 PM
MDS2KAp1's Avatar
I have problems grinding going into second every 1 out of 15 or so (only under hard accelerating) It is very embarrassing to grind in second. People think I dont know how to shift, but I am doing nothing different!
And that makes sence about the second one Bobby.
Old Jan 28, 2007 | 12:53 PM
i have same issue with mine. you have to clutch in and throw hesitation before hitting second. what was nice with supercharger you could delay longer and make up for the hesistation
Old Jan 28, 2007 | 03:20 PM
JulieU's Avatar
Administrator
You can try. Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager. Just take it to your local Honda service department (preferably the Honda dealer where you bought your car, if applicable) and talk to one of the service advisors.
Old Jan 28, 2007 | 06:53 PM
yea problem is.. bill the guy at honda is all about revenue. he will not do anything under good will. you need to get in good with service advisors like i did and they will sneak it under his nose
Old Jan 29, 2007 | 05:35 AM
SgtSlaughter's Avatar
Luckliy for me, I only have problem #2. I gotta find a time to call my local dealer and try to sweet talk them.
Old Jan 29, 2007 | 07:24 PM
Ch0pper's Avatar
Actually guys, aren't all TSB's covered no matter if you have remaining warranties or not ?
I know I've had TSB's performed with out of warranty cars.
EDIT: This is what Julie said, but I copied it from the Bulletin
"Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work"
