Ark-La-Tex S2000 Owners Covering Arkansas, Louisiana, and East Texas
window motor
Old Mar 8, 2009 | 07:44 AM
killereclipse's Avatar
Default window motor
no would happen to have a spare window regulator, would they? I need one for the passenger. I rolled the window down and now it will not go back up.
Old Mar 8, 2009 | 07:45 AM
S2Krazee's Avatar
Did you accidentally flip the switch on the drivers door?
Old Mar 8, 2009 | 09:48 AM
i wish. I checked that already, cause when i searched it on the forum, that seemed to be the mistake most people make.
Old Mar 8, 2009 | 10:01 AM
SgtB's Avatar
I'd pull the motor connector and check for voltage before changing it.
Old Mar 8, 2009 | 06:21 PM
S2Krazee's Avatar
What is the tolerance?
Old Mar 8, 2009 | 07:03 PM
s2qwik's Avatar
maybe a fuse? well, now u can always be topdown!
Old Mar 8, 2009 | 07:20 PM
S2Krazee's Avatar
I'd imagine it's a good way to live. Never tried top down 24/7.
Old Mar 10, 2009 | 09:55 AM
SgtB's Avatar
Should just be battery voltage around 13v. Measure it while the defunct button is pressed. If there is voltage than the motor is bad. You could also measure the resistance of the motor coil. It should be in the 10-20ohm range. I'm sure the helms has the exact spec.
Old Mar 10, 2009 | 12:29 PM
i got the problem solved, It ended up being that the wires in the harness was loose in the passenger side, when it was pushed back in then everything was fine again. thanks for all your help though guys.
Old Mar 11, 2009 | 06:11 AM
tof's Avatar
tof
sweet.
nice when a nasty problem turns out to have a simple solution.
