Australia & New Zealand S2000 Owners Members from the land downunder.
Alignment Question
Old May 7, 2008 | 03:46 PM
weez3r's Avatar
Default Alignment Question
I recently installed a set of lowering springs and a whiteline front swaybar. So im assuming that the factory alignment specs no longer apply. My main concern is the rear toe. The UK spec is 6mm iirc. So if i have a larger front sway bar, which in theory make the car understeer a bit more. Should i have less toe in, lets say 3mm instead of 6?
Old May 7, 2008 | 03:50 PM
TAAXED's Avatar
I'd keep it at 6mm total...
I'm usuing the whiteline front SB
Old May 7, 2008 | 04:23 PM
AusS2000's Avatar
No, it makes it less prone to oversteer. It is still a predominantly oversteery car.
My vote is to keep the UK specs.
I use H&R lowering springs and Whiteline front sway bar.
Old May 7, 2008 | 04:33 PM
weez3r's Avatar
Thanks for that
so 6mm total means toe in 3mm each side?
Old May 7, 2008 | 04:39 PM
AusS2000's Avatar
Yup
Old May 15, 2008 | 08:16 PM
ss2kwhite's Avatar
Does anyone know if there are factory settings are for a wheel alignment with factory wheels and S02 tyres. if so what are they? Do I have to quote these to the serviceman or would they know what to do ?
Can someone reccommend a good place for a wheel alignment in Sydney west and how much does it cost roughly?
thanks
Old May 15, 2008 | 10:17 PM
TAAXED's Avatar
depends how aggressive you want it, search up the UK settings and quote that to them if your not sure.
It should cost about $75
Old May 16, 2008 | 04:11 PM
STAIN's Avatar
im running -3.2 each side on 18's
H&R lowered springs & cusco bar
Old May 16, 2008 | 11:13 PM
MattG's Avatar
ss2kwhite - I run stock rims with S02s. I just get my local bridgestone dealer to do the alignment when I buy the tyres. That way I can haggle a bit and get a discount on the alignment cost.
I use the UK alignment settings, print them out and hand it to the people doing the alignment, as they differ to the Australian factory settings.
Old May 17, 2008 | 02:11 AM
ss2kwhite's Avatar
ok thanks - but why UK settings - r they better than Aus ones?
