Thermostat Housing removal
Anyone got any tips for getting at the thermostat housing bolts, because holy shit the cold side of the engine bay, they made absolutely no consideration about maintenance when they put that shit show together!!!
Below from online service manual page 281.
1. Drain the engine coolant (see page 10-9).
2. Remove the lower radiator hose and the thermostat cover, then remove the thermostat.
3. Install the thermostat with a new rubber seal.
4. Install the thermostat cover and the lower radiator hose.
5. Refill the radiator with engine coolant, then bleed air from the cooling system (see step 7 on page 10-9).
6. Clean up any spilled engine coolant.
http://s2000.club/OM/2000-08%20Honda%20S2000%20SM.pdf
Good luck!
Good luck!
Okay just gonna wrap this up, for those who also have trouble with this too.
Long story short, you need to remove your air intake, be it stock or otherwise.
Remove the alternator (which seems to be the play for working on almost anything on the cold side)
Then you should be able to access the hoses an bolts needed to remover the thermostat housing.
Calzonii
Feb 21, 2016 12:37 PM
