Auto Racing Discussion F1, IRL, Champ Car, Nascar, WRC, BTCC, etc. Discuss recent races, results.
2011 F1 Technical Reg Changes
Old Nov 30, 2010 | 08:27 PM
samerthehammer's Avatar
Default 2011 F1 Technical Reg Changes
Here is a small article on formula1.com about the changes next year. http://www.formula1.com/news/feature.../11/11579.html
No adjustable front wing, and instead an adjustable rear wing that will activate when the driver is within 1 sec of the driver ahead at predetermined points on the track. I Don't know how this will turn out next season. I didn't know there was going to be a predetermined weight distribution. The return of KERS will be interesting. The '09 season, only Ferrari and McLaren used KERS the entire season. It will interesting how the other teams will integrate it and if Ferrari and McLaren have made advancements to KERS.
Old Nov 30, 2010 | 09:04 PM
ytdlite's Avatar
because of the kers package there is a weight allotment increase to 640kg with front-rear weight distribution, which is expected to be regulated to 46.5% front, 53.5% rear. now riding on perelli tyres. and if thats not enough of a challenge for the engineers add in this optional predetermined point on track, with in 1 second of the car ahead, electronically activated movable rear wing. the wing thing is just silly. the track marshals have a hard enough time metering out the current rules infractions, this one will be in the courts early and often.
Old Nov 30, 2010 | 09:07 PM
Oh yaa I heard about the increase in weight. This will suck for the bigger drivers, so it makes it tougher to move the ballasts around.
Old Dec 1, 2010 | 12:31 AM
SeekeR1's Avatar
I'm not convinced of the efficacy of the movable rear wings - from what is written, it sounds like there is minimal driver control of a "tech" that is intended to improve passing... which sounds too much like "someone" controlling the amount of passing - too contrived for my taste.
Having typed that, I am very eager for the testing season to begin
Old Dec 1, 2010 | 04:29 AM
timrocks311's Avatar
the increase in weight is meant to help bigger drivers, so they have more ballast to play with.
Old Dec 1, 2010 | 04:33 AM
i like that they are trying to increase passing, but this seems overly complicated. why does it have to be only at specific points on the track? that means for each race, someone has to determine this and setup some kind of controls to accomplish this. seems ridiculous. there should be an easier way.
Old Dec 1, 2010 | 08:48 PM
I thought that it would be more advantageous for smaller drivers because you have more freedom to move the weights around compared to a bigger driver. I guess it will help the bigger drivers that they have a set on the weight distribution.
Old Dec 23, 2010 | 11:09 PM
darrylsaladino's Avatar
The exception of minimal parts solely associated with adjustment of the section, no parts of thesection in contact with the external airstream may be located any more than 355mm from of the carcentre line.
ytdlite
May 9, 2011 05:56 AM
S2K Type R
Nov 6, 2009 06:33 AM
GPMike
Mar 17, 2009 02:35 PM
Triple-H
Mar 11, 2009 04:50 AM
matrix
Nov 8, 2003 06:34 AM
