blueprint's *Grand Prix White* AP1 Build
#171
Thanks! Car should be up and running. The AC is the part that will take some time since we are re-routing the entire plumbing but as soon as we have her tuned i'll post my impressions.
I'll be happy with 260ish on pump gas.
On a K24 no, it would not be safe to run to a 9k redline. I'll be capping mine to 8k.... I know many K20's that do it all day but there is no power to be made above 8400.
#172
New Ballade Motor is up and running. Very similar setup to my own car.
Untitled by blueprint012, on Flickr
#174
Originally Posted by andrewhake' timestamp='1473834724' post='24061653
It boggles my mind that people think the K series is a better engine than the F20/F22C. I just. don't. get it.
This configurability allows the engine to respond to modification much better. To greatly simplify it, it allows the engine to make both high top end power and low end torque by varying the amount of valve overlap based on RPM & Load.
We'll see how she compares to my old setup on the same dyno.
Interested to see the results though either way.
#175
Originally Posted by blueprint' timestamp='1473882939' post='24062092
[quote name='andrewhake' timestamp='1473834724' post='24061653']
[/quote]
Your certainly entitled to your opinion and im not going to change your mind on this topic.
IMO... the K series is a better engine than the F series. The K evolved from the F and has evolved throughout the years.
Plenty of K series out there putting down some incredible power and the sky is the limit in terms of potential. Im curious to see how she does vs. my old setup.
#176
Let's just be happy that there's options. Both sides of the arguement have their points. As the S2000 ages and people need to rebuild or replace motors it's good to have the option of a K series. In a couple more years I'm sure both an F24 and K20/24 will be developed well enough where swaps and builds will be more common and reliable.
#177
#180
I totally forgot about this build thread... Big update.
First and foremost i'd like to thank Alex, Matt, Aaron and crew over at Ballade Sports for making this happen for me.
Back in March of this year I spoke with Alex and decided on doing a K24a2 swap for my AP1. The Potential, Availability and Cost of the K series really appealed to me and made the decision easy. After mapping out what this swap entails we put everything to paper and went to business.
Breakdown:
Engine:
K24a2 2006 TSX Block
RS Machines Pistons 11.1:1 Compression
Stock K24a2 Rods
Stock K24a2 Crank
Acura RDX 440cc Injectors
50 Degree VTC
F Series Intake Manifold
F Series Throttle Body
Ballade Sports K Series Header
Ballade Sports Anodized Valve Cover
Ballade Sports Intake Arm
Ballade Sports Adapter Plate
Innovative Motor Mounts
Stock S2000 Airbox
K&N Drop In Filter
K20 Oil Pump
K20 OIl Pan
K20a2 RSX Type S Head
Built and Ported by Port Flow
Brian Crower Stage 2 Cams
Supertech Valves
Supertech Valve Springs
Supertech Retainers
Clockwise Motion Oil Pan Baffle
Tractuff Oil Pump Plate
Berk Test Pipe
HKS Hi Power Exhaust
Rywire Wiring Harness
Hondata K-Pro
Tuned by: Import Auto Pro's
Dyno Graphs:
2008 Honda S2000 AP2
Stock F22C
Ballade Sports Header
Ballade Sports TCT
Ballade Sports Correction Gear
K&N Drop In Filter
Berk Test Pipe
Invidia Exhaust
HP: 212.04
TQ: 143.72
My K24 Swapped AP1. Mods listed above.
HP: 252.24
TQ: 174.34
Pictures:
IMG_2624 by blueprint012, on Flickr
IMG_2672 by blueprint012, on Flickr
IMG_2675 by blueprint012, on Flickr
IMG_2678 by blueprint012, on Flickr
IMG_2685 by blueprint012, on Flickr
Video:
Overall the entire build exceeded my expectations. I wanted to keep the build as simple as possible and in the end I believe we accomplished that. As far as where we go from here that's still up in the air.
Special Thanks to:
Ballade Sports
Portflow
Rywire
MrSidewayz aka Ian Stewart
Breakdown:
Engine:
Stock K24a2 Rods
Stock K24a2 Crank
50 Degree VTC
Stock S2000 Airbox
K&N Drop In Filter
K20 Oil Pump
K20 OIl Pan
Supertech Valves
Supertech Retainers
Berk Test Pipe
Hondata K-Pro
Dyno Graphs:
Stock F22C
Ballade Sports TCT
K&N Drop In Filter
Berk Test Pipe
Invidia Exhaust
HP: 212.04
TQ: 143.72
HP: 252.24
TQ: 174.34
Pictures:
Video:
Special Thanks to:
Ballade Sports
Portflow
Rywire
