King Tut's 2006 AP2 Laguna Blue Pearl ( LBP ) Time Attack Build
I figured it was finally time to start my build thread on S2ki. I made the decision last year, that I was bored with my BMW Individual 2012 BMW E92 M3 in Laguna Seca Blue with Rust Brown interior. I knew that I would never track this $60k car, and while I have a BMW SpecE30 racecar, I wanted to see what kind of lap times I could put down in a faster car. I had previously owned a turbo Subaru BRZ, and the Honda S2000 came to the top of the list. The prices for used BRZs, just weren't where I wanted them, so I ended up looking only for Laguna Blue Pearl Honda S2000s. I sold my E92 M3 back to Cali, and the next week I was lucky enough to find John @ LHT Performance in the Tampa/St. Pete area selling just the car I wanted for the right price with just over 100,000 miles. The plan since before I purchased the car was to build a NASA TT3 time trials / time attack car based around a turbo kit. I know that many have attempted this and most have failed or not gotten the results they desired. That is part of the motivation of this build. I want to prove that you can build a competitive and reliable turbo S2000 time attack machine. The plan was to use this year to build the car and get in as many test days on track as possible. I have already run the car at NOLA Motorsports Park, Barber Motorsports Park, and I will be at Atlanta Motorsports Park this Sunday and heading up to Memphis International Raceway in April. It took me a long time to choose what I believe is the turbo kit that best matches my goals. I should have the PTUNING GTX3076R turbo kit and oil cooler by the end of April. All questions, comments, and suggestions are appreciated.
Engine / Performance Modifications:
PTUNING GTX3076R Turbo Kit
PTUNING Oil Cooler
PTUNING Oil Distribution Block
HKS Hi-Power Single 75mm Exhaust
Hondata FlashPro
Injector Dynamics ID1000 Fuel Injectors
Full Blown FB340-2 Fuel Pump
Mr. Sideways 3 Inch Dual Pass Radiator
14" SPAL High Performance Cooling Fan
McMaster-Carr Vacuum Block
Moroso Performance Catch Can
Drivetrain Modifications:
ACT H021 Clutch Pressure Plate
Honda OEM AP1 Flywheel
Honda OEM Clutch Disk
Honda OEM Throwout and Pilot Bearing
Wheel / Suspension / Brake Modifications:
WedsSport TC105N 17x9 +49 Dark Blue Metallic Wheels (Square)
Michelin Pilot Super Sport 245/40/17 Tires (Square)
949 Racing Hub Centering Rings (Track)
WedsSport TC105N Center Caps (Street)
Ohlins Road and Track DFV Coilovers
J's Racing S2 Camber Joints
2001 Honda S2000 AP1 Rear Sway Bar
Stoptech Trophy STR40 Front Big Brake Kit
Stoptech/Centric Premium OEM Rear Rotors
Stoptech SS Brake Lines
PFC08 STR40 Caliper Front Pads (Track)
PFC97 OEM Rear Pads (Track)
Stoptech Street Performance Pads (Street)
Motul RBF 600 DOT 4 Racing Brake Fluid
Vorshlag 17mm Hex M12-1.5 Black Lug Nuts
Interior Modifications:
Hard Dog Double Diagonal Roll Bar
Autometer Dual Gauge Pod
AEM Failsafe Boost/AFR Gauge
Innovate Oil Pressure/Temp Gauge
Exterior Modifications:
Forbidden USA Mugen Replica Double CF Hardtop
APR GT-250 67" Wide Carbon Fiber Wing (S2000 specific mount)
Rockstar Garage Front and Rear Hardtop Brackets
Sparco Tow Straps Front and Rear
Future Modifications:
Hyperco 700 lb Front and 600 lb Rear Springs
Eibach Adjustable Front and Rear Sway Bars
Anorexicpoodle Front and Rear Adj End Links
AMB Tranx 260 Transponder Direct Power
Pictures:
PTUNING Oil Cooler
Hondata FlashPro
Pictures:
Very nice!
That's very nice. I'm really liking the Wed's in that color.
Good luck with the turbo setup for the track... that's a very very difficult and expensive road. Read through the R&C forums, lots of turbo builds have failed numerous times. The owners either ended up selling the car afterwards, or reverting back to NA.
