California - Southern California S2000 Owners Southern California S2000 Owners
Check Engine Light
Old Nov 25, 2006 | 02:00 PM
Currahee474's Avatar
Default Check Engine Light
I randomely got a check engine light just now. Its definately not time for an oil change and i was wondering if anybody in 626 area had the OBDII scan tool thingy. If you do it would be greatly appreciated if you helped me out. Thanks.
************EDIT*********
i got 2 codes. First is P1456 "Auxillary Emission Control" and i scrolled to the second one which said the same thing but it had a P over a D in the right hand corner. what does this mean??
Old Nov 25, 2006 | 02:12 PM
Mad_Paradox's Avatar
you can go to a kragen or autozone i am pretty sure it's free for them to check the code
Old Nov 25, 2006 | 02:14 PM
sweet! danka!
Old Nov 25, 2006 | 02:16 PM
Kel's Avatar
Kel
Did you just pump gas? A loose gas cap will throw a CEL.
Old Nov 25, 2006 | 02:17 PM
Nicotunes's Avatar
Good point.
Old Nov 25, 2006 | 02:39 PM
no lol its not the gas cap i've done that before.
its code p1456. info in first post.
************EDITED************ look at first post please thanks.
Old Nov 25, 2006 | 02:41 PM
B.C.'s Avatar
Loose Vaccum tube? Air Pump is dead?
Old Nov 25, 2006 | 02:57 PM
so i take it its not a simple fix. am i good to drive for the next 2 days or is it a right away situation?
Old Nov 25, 2006 | 03:05 PM
s2k_dreams's Avatar
Sounds like it has something to do with the emissions systems so it should have no bearing on performance. You are probably just polluting the atmosphere. Like BC said it could be an air pump that failed, I think it could be a sensor also. good luck with fixing the problem, the hardest part ids always finding what the problem is.
Old Nov 25, 2006 | 03:10 PM
screw it this seems too difficult to find i'll let honda fix find/fix it.
