1990 honda prelude, quick question
Old Sep 24, 2002 | 05:44 PM
blue2k2s2k's Avatar
Default 1990 honda prelude, quick question
Problem: Car sometimes does not start. Makes a clicking noise (I assume this
would be the starter clicking) However, other times, the car does start
normally. It is not the car battery
Solutions: I am thinking fuel pump? Main relay?
Help: What do you think? Any ideas will be much appreciated.
Old Sep 24, 2002 | 05:52 PM
CG's Avatar
CG
Sounds like a loose battery cable. Take them off, clean them up and see what happens. Heck, try tightening them up, it might be all you need to do.
Old Sep 24, 2002 | 11:50 PM
Kwando's Avatar
Starter solenoid.
Old Sep 25, 2002 | 05:13 AM
JonasM's Avatar
All good suggestions. Also check the Starter ground cable. I had a similar problem in my old Accord (or was it my CRX...) , and it turned out that the ground cable was pretty rusted out.
JonasM
Old Sep 25, 2002 | 07:05 AM
blue2k2s2k's Avatar
CG, Kwando, and JonasM thanks for your quick responses! I will try all of these out when I find time.
Old Sep 27, 2002 | 08:55 AM
brushman's Avatar
[QUOTE]Originally posted by blue2k2s2k
[B]Problem: Car sometimes does not start.
Old Sep 27, 2002 | 10:49 AM
Optikal's Avatar
I have had a similar problem, but on a 86 ford bronco. I was able to bypass the starter solenoid which turned over the engine. It was a clue that the solenoid needed to be replaced.
VIXNU
Nov 19, 2012 03:30 AM
the fan
Sep 26, 2011 06:04 PM
y0itzCARL
Dec 6, 2009 08:27 AM
r0cket247
Dec 4, 2009 06:05 AM
SlickS2k
Apr 19, 2004 12:19 AM
