AWD Tips?
Correction for AWD is the same as FWD as well. To correct understeer, ease off the gas. To correct oversteer, ease into the gas.
AWD is unstoppable. just floor it. you have way more traction then RWD or FWD. AWD >>> fysics, FTW!!
Left foot braking is key to getting a turbo AWD car to be very fast. Plenty of rotation and keeps the turbo spooled up and on power. I just had a long conversation about this with instructors at mid-ohio (NASA Nationals) and the fastlane school. These recommendations are based on data acquisition analysis.
Originally Posted by aklucsarits,Sep 20 2006, 04:58 PM
^^^ No, it would be the opposite correction for a RWD car - More gas to correct understeer, less gas to correct oversteer.
Andrew
Andrew
are you talking about left foot braking in corner?
Originally Posted by s2kpdx01,Sep 20 2006, 12:23 PM
huh? Adding gas to correct an undsteer is not a good idea. Letting up on the gas will cause the back to rotate correcting your undsteer. If you are oversteering less gas will cause the back to unweight and exacerbate, not correct, the problem. If you are oversteering because you hammered it from stand-still fine, but if you are oversteering in the middle of a corner at near 10/10's you need to keep on the gas and try to turn into the slide if possible. Letting off the gas when you start to oversteer in a corner usually spells disaster no matter which wheels your car is driving.
If you are oversteering in a corner, then you have also already exceeded "10/10ths." You've already exceded the available rear grip in the corner by feeding in too much gas to the point where you have broken rear traction. The rear tires are already sliding wide, and at that point, if you want to catch the rear end before you end up going for a loop, the way to achieve that in a RWD car is to ease off the gas, and possibly feed in some countersteer if needed.
But what do I know? I'm just an SCCA Solo2 instructor...
Andrew
Originally Posted by aklucsarits,Sep 20 2006, 06:53 PM
If you are understeering in a corner, then you have already exceeded "10/10ths." You've already exceded the available front grip by entering the turn with too much momentum. So by definition of 10/10ths as the absolute limit of the car, you are at 11/10ths or 15/10ths or whatever you want to call it as the car understeers. The front tires are already sliding wide, and at that point, if you want them to tuck IN, the way to achieve that is to step on the gas in a RWD car.
If you can add enough power to rotate the car around sliding front tires, more power to you, but that's not common. If the front tires are sliding and you add more momentum to the vehicle how are they going to start gripping?
