camber tires
Old Jan 23, 2011 | 02:52 PM
flacoloco's Avatar
Default camber tires
http://www.jaylenosgarage.com/extras/car-p...ber-tires/#more
very interesting concept. it might even help pull +1 g turns without really messing with the suspension
Old Jan 23, 2011 | 03:11 PM
GrandMasterKhan's Avatar
nniicee!
Old Jan 23, 2011 | 03:19 PM
Marekv's Avatar
I can just say cool but this is a repost.
https://www.s2ki.com/forums/index.php?showt...&#entry19236578
Old Jan 23, 2011 | 03:25 PM
flacoloco's Avatar
OMG, dear baby jesus, oprah, tom cruise saves us, a repost!!!!!
Old Jan 23, 2011 | 04:14 PM
Christople's Avatar
scientology?
Old Jan 24, 2011 | 06:14 AM
2wheelsmoker's Avatar
How this help with aggressive turns where the cars lean?
Old Jan 24, 2011 | 06:49 AM
ZDan's Avatar
See discussion in Wheels and Tires.
You'd mount them with the shorter sidewalls facing OUT, such that you get the same amount of tire camber at the road with less (or zero) camber at the wheel. Going straight ahead, you're rolling more on the inside of the tread, just like with a normal tire with negative camber at the wheel. During cornering the outside tires load the contact patch more evenly across the tread width, just like a normal tire with negative camber at the wheel.
Old Jan 24, 2011 | 12:25 PM
Bloodred's Avatar
[QUOTE=ZDan,Jan 24 2011, 07:49 AM]See discussion in Wheels and Tires.
Old Jan 24, 2011 | 01:04 PM
aklucsarits's Avatar
They are cambered the wrong way.
If you want more lateral grip on a car, you want MORE negative static camber. But these tires are designed to eliminate negative static camber...
Andrew
Old Jan 25, 2011 | 06:08 AM
AngryTurtle's Avatar
id rather have this car then those tires,
