Head Gasket replacement on '90 Corolla?
Old Oct 14, 2009 | 06:45 PM
JTNY's Avatar
Thumbs up Head Gasket replacement on '90 Corolla?
Hey folks,
I have a 1990 Corolla that has a blown head gasket. Anyone have any idea how much it would cost or how many hours it would take a mechanic to replace? I just discoverd this a few days ago and have since stopped using the car.
Old Oct 15, 2009 | 07:17 AM
David1's Avatar
It's more than the car is worth. Plan on 1k for gasket, head work, oil, coolant, belts and timing belt. And that is if the head is even reusable.
Old Oct 15, 2009 | 08:37 AM
Mr.E.G.'s Avatar
If you can't do it yourself it may be worth while to scrap the car.
The procedure would involve removing everything that is attached to the head which would include your intake and exhaust manifold, the timing belt and any ancillary wires, cruise control cables, etc. that may be attached to it. Once you have all of that stuff off, removing the head is pretty simple. The head will have to be machined which typically runs about 80 bucks. Then you have to put it back together replace the head gasket and reinstall the head. The intake manifold gasket and other gaskets will likely be destroyed and will need to be replaced. You should also replace the timing belt, water pump, etc. while you have everything apart.
Old Oct 15, 2009 | 09:09 AM
sahtt's Avatar
cash for clunkers over yet?
Old Oct 15, 2009 | 12:11 PM
David1's Avatar
It would not qualify.
Old Oct 15, 2009 | 01:53 PM
Mondo131's Avatar
I am assuming it is a 4-Banger?
Do it yourself. HG's cost 100-150. 4-Banger HG replacements I have found to be easily done on a weekend.
Take it to a shop, 1000+
Old Oct 16, 2009 | 08:07 AM
JTNY's Avatar
Thanks for the tips fella's. sounds like this car is gonna be scraped. the $800-1000 cost estimate exceeds the value of the car practically.
LAE
Nov 25, 2018 04:45 PM
Sideways
Mar 6, 2015 06:15 AM
RollAxis
Dec 23, 2012 09:55 PM
slociviccoupe
Mar 26, 2009 04:43 PM
jal3lee
Oct 14, 2005 11:11 AM
