View Poll Results: HP -> Acceleration... not Torque!
HP is more important than Torque
58.62%
Torque is more important than HP
41.38%
Voters: 203. You may not vote on this poll
Old Feb 23, 2003 | 12:22 PM
  #31
FCGuy's Avatar
[QUOTE]Originally posted by ultimate lurker
[B]Most jet aircraft are rated in lbs of thrust.
Old Feb 23, 2003 | 12:23 PM
  #32
micah's Avatar
[QUOTE]Originally posted by FCGuy
[B]Ah, Bruce Augenstein's post once again
Maybe it's time to write an SAE paper on this.
Old Feb 23, 2003 | 12:34 PM
  #33
FCGuy's Avatar
I think I see your point, micah. One of the problems with any of these tq/hp discussions gets down to language. If we all talked math & physics, and were patient, I think it would become clear. But when we use imprecise language, and run up against the usual internet short attention span ... Who's to say what "pulls harder" means??
BTW, I'd almost pull back my vote since I don't know what Destiny2002 meant by "more important than...". But if you want to know accel, give me the hp and weight.
Old Feb 23, 2003 | 12:51 PM
  #34
ultimate lurker's Avatar
Actually, Bruce's write up is pretty accurate, and one of the best communications pieces on this topic - and it has been that way since 1995!!!
On the topic of Integras, the GS-R only made 1 lbs-ft more torque. Additionally, it weighed 2667 lbs vs. 2550 for an Integra LS. The gearing was about 3% tighter in the first two gears, and then 8-10% tighter after that, while the rev limiter was 16% higher.
If both cars were in first or second gear, the peak thrust to weight ratio for a stock GS-R was almost identical to the LS. Its just, as Bruce noted, the GS-R pulls _longer_. But it didn't put you back into your seat any harder. Which is exactly what Bruce was talking about when he said it didn't _feel_ any faster.
UL
Old Feb 23, 2003 | 01:15 PM
  #35
FCGuy's Avatar
When choosing between an Integra LS and a GS-R, practicality won out. I bought the LS knowing that the real-world performance difference wasn't great, I had more relaxed cruise rpm, and could use cheap gas. But yah know what, good as any Integra sounds, I missed not having that VTEC wail. Which is a good part of what it is all about, isn't it?
Old Feb 23, 2003 | 03:05 PM
  #36
micah's Avatar
[B]I think I see your point, micah.
Old Feb 23, 2003 | 04:51 PM
  #37
xpander4's Avatar
S2000s can beat mustang GTs with twice our torque. I think HP is a lil more important
Old Feb 23, 2003 | 05:00 PM
  #38
FYRHWK1's Avatar
[B]"hp is calculated" - fallacy
Horsepower is power.
Old Feb 23, 2003 | 05:59 PM
  #39
Actually, in the case of inertia (roller) chassis dynos, you're not measuring torque either. Only with a brake dyno do you truly measure torque. But, simply put, to say that torque is measured and hp is calculated (as quoted) is a gross generalization - this coming from a brake/absorbtion dyno owner.
As for the exhaust tip, I suggest erring on the smaller side. I think you'd want to keep the exhaust gas velocity on the high side - v^2 you know ;-)
UL
Old Feb 23, 2003 | 06:07 PM
  #40
FYRHWK1's Avatar
[B]Actually, in the case of inertia (roller) chassis dynos, you're not measuring torque either.
